1 hour ago, Loren said:
Try 9895
You're the man! Thank you so much, I can't tell you how much that makes me smile, having a working radio!
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
9 hours ago, Craig Joplin said:
2002 Boxster S
Radio CR-220
Pushed TP button for 10 seconds.
Becker 1 came onto screen. Scrolled right:
47/98
Type 4362
We need the serial number to help you - scroll right again.
8 minutes ago, McMoru said:
May I ask the radio activation code for the one below?
CR-2200
Becker
Type 4466
Serial # Y5014102
24/99
Thank you.
Try 0560
I have a 2001 Porsche Boxster S with a CR 220 radio. I disconnected the battery to pull the seats for reupholstering. As you know, I lost the radio code and now have no music. The radio SN is Y5022900 and Type 4362. Any help is appreciated and thank you in advance!
I finally found a place to get what I need to get my radio working after battery change.... great
Can you please get me the code for
Boxster s 2000
Radio car 220
Serial. X5035762
Type 4462
24/99
Thanks in advance... stephan
Try 0647
Boxster s 2000
Radio car 220
Serial. X5035762
Type 4462
24/99
Try 8723
It wI finally found a place to get what I need to get my radio working after battery change.... great
Boxster s 2000
Radio car 220
Serial. X5035762
Type 4462
24/99
It worked ... you are the best. I thought this would be a nightmare to fix and there you are. It is nice to see that there are still good people out there willing to help.
Thanks again
Stephan
Just now, BEZ53 said:
Thanks! - I tried but no luck with 0647. Any other suggestions?
Did you get the serial number through the procedure in the Lost Radio Code FAQ?
If you did not, then please use that procedure to get the correct serial number.
If you did and the serial number you gave me is correct then your radio was likely repaired by someone other than Becker and I can not help you.
My apologies! I sent the wrong serial number initially - the last number is 8 and not 0. The radio serial number is Y5022908 type 4362.
Try 0721
I have a 99 Porsche Boxster. I just bought it, the radio didn’t work, I found a blown fuse, replaced it, and now I need a code. I called a dealership and they gave me a code 9025 per my VIN and that didn’t work. Guess it has been changed because I have a sticker on the top of my radio that says “original replacement part” Becker of North America. The only number I can find is stamped on the side.
BE4462W5011297 does that mean anything? Also how will I find this info again if some answers on here? If not my email is heathmcgaha@yahoo.com just in case.
Try 6523
Thanks in advance, wife left lights on and killed battery. Now can’t turn on the radio. Original owner passed and I bought from his son. No idea where card is
Serial #x5030082
Serial #x5030082
Try 4240
