8 hours ago, salooski said:
Hello, and thanks in advance.  I'm hoping you could send me the radio code for a CR-210, Serial number V5004418 (1997 Boxster 986).  Appreciate your help!
Try 1010
  • Thanks 1
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
3 hours ago, curry999 said:
Hey just replaced my battery and need the code for the radio.
Becker cr210
Model# 2182
Serial# T5002676
thank you
Try 4517
  • Thanks 1
Had to replace my battery and don't have the code. Can you help?
CDR220
24/99, type 4462
X5035138
Thanks in advance, Jeff
2 hours ago, jeff986 said:
CDR220
24/99, type 4462
X5035138
Try 0658
That worked! Thanks so much. Just donated $30 to the org as a token of my appreciation. Cheers, Jeff
4 hours ago, Vegas Mustang said:
Greetings,
Battery has died and I can't find the code. Please help if possible:
CDR-220
Type 4462
SN 25013282
Try 2439
Hey!
I took my car into the shop and when it came back my 2000 Porsche Boxster’s radio asked for a code. I have no  idea what it could be but if y’all could help me the would be amazing!
type- 4462
serial number- Y5040989
radio- CDR-220
8 hours ago, Brianna said:
Hey!
type- 4462
radio- CDR-220
Try 8907
  • Thanks 1
Looking for help with my 2000 996 C4 with a radio card the does not work.
My radio code is not working and the one the Porsche Dealership provided also does not work.
Radio CDR-220
My radio card details:
BE 4462 W 5010425 code 4906. (Does not work)
The Porsche Dealer provided a code of 1528. (Does not work)
In addition, I have a Becker card with the following serial number CDC-3 X1039282.
Thanks in advance for everyone help.
Radio CDR-220
If that is the correct serial number (per the procedure in the  Lost Radio Code FAQ) then it is likely that radio has been repaired by some 3rd party other than Becker. If that is the case I can not help you.
Replaced my battery and the radio code for my CR-220 isn’t working. Bought the car used so it’s possible the code is incorrect. Looking to try another code. Thank you!
Radio - CR-220
SN - X5020347
Type - 4362
10 minutes ago, Stefano Sharma said:
Radio - CR-220
SN - X5020347
Type - 4362
Try 0698
Thanks Loren,
Based on the serial numbers I do have what 4 digit code do you think would work?
52 minutes ago, Colin Carter said:
Thanks Loren,
If the code I gave you does not work then you need to get Becker to unlock the radio or replace the radio.
1 hour ago, Colin Carter said:
Sorry, you have not provided a code. I was curious if they one you had is different than the one I have on the radio card.
The code I got was 4906  - which you said did not work.
4 hours ago, Brandon Bohl said:
Hi I could use a radio code for my 1999 Porsche Boxster: my Becker CDR 220 details:
- Serial Number X5023735
Can anyone assist?
Try 8383
