With the help of CDR 210 manual download and reading several threads and forums,
I was able to following the instructions and read the following codes:
R2896
V5010579
The last message returned was END which has not been documented that I have found.
I tried entering the above codes per instructions:
2896 - display goes to blinking 2
5010 - display goes to blinking 5
0579 - display goes to blinking 0
After several tries the display goes to WAIT
and eventually it will let me try again.
I found another thread that appeared like one of the above codes has to used against a master code list.
Any ideas on why the above codes did not work?
I found a place to order the removal tool to pull the radio and look for more info if that is next steps.
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I found a thread on another forum that indicated the Signal Seek button (#7) is used to save the code but it did work for me.
Hello, please help!
CR-210
serial # T5003704
Thank you!! 🙏
Edited by jamo23
10 hours ago, Ckid Photography said:
Locked radio
2001 boxster.
Don't know code. Here is serial number.
thanks in advance
Please verify your radio serial number using the method in the  Lost Radio Code FAQ.
I have read the thread and cannot find my code.  I disconnected the battery and the radio now wants the code to unlock.
1999 Boxster
Radio - CDR-220
Type - 4462
Serial Number - ??036505
Can you assist?
Edited by Loren
VIN removed
1999 Boxster
Radio - CDR-220
Type - 4462
Can you assist?
Try 1326
Wow!  737 pages of lost radio codes.  Sir, you are a trooper.  Bought my first Porsche recently, a 1999 Boxster, but the radio code wasn't available.  It's a CDR-220 type 4462 with a serial number of X502 1627.  Many thanks if you are able to help.
Try 4315
  • Like 1
Hello! I lost my radio code from Becker CDR 220 of my Porsche Boxster.
Model BE 6625
Serial number 25011003
Thank you!  🙏
Edited by Tehkultura911
Serial number
Model BE 6625
Thank you!  🙏
Try 9019
  • Like 1
Hello,
I have just come back to the USA after 9 years overseas (Navy guy).  My 1999 Boxster with the CDR 220 deck in it was in Government storage during that time and on retrieval last week I'm getting the "Wait" followed by Code ****.  My Serial # is W5012297.  Any help would be amazing!
Thank you!
Edit: added the other 2 numbers it displays when cycling past the serial #
TYPE 4462
CD CDP2065
Edited by Bryce Brown
