I just bought a 1998 Boxster with the CDR-210 radio that is not original. The previous owner never bothered to get the code and just didn't use the radio.
I found this serial number : W5022491
Can someone get the code to unlock the radio?
Thanks.
  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
4 hours ago, Richard Grantham said:
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type BE 4367
serial # X5010361
Thanks for your help 🙂
Try 0810
18 hours ago, Loren said:
Try 0810
Thank you Loren, very much appreciated.
Hello,
Becker CDR 220
type BE 4367
serial # X5010361
Hello,
Becker CDR 220
type BE 4367
serial # X5010361
I answered your post - just above your second post.
Thanks.
Would I need to send something else to get an unlock code?  I really appreciate that you are doing this for us.
,w
,w
Sorry, I missed your original post.
Try 5054
2 hours ago, VoilaGT3 said:
Hi Loren,
Could you help with the code for my 996's cdr220.  It is a replacement radio and I lost the code.
Many Thanks!
4462
Y5038169
Try 9521
  • Thanks 1
Hi Loren,
I’ve tried lots of places, I’m after the codes for my stereo & Nav,
model BE2580
serial number 25106557
nav is PO8150129152/01
respect for maintaining probably the longest most active thread 🤙🏼
6 hours ago, SuperKev said:
Hi Loren,
model BE2580
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi Loren,
Looking for a code for my radio.
CDR-220
Becker 1
Type 4462
48/98
Serial X5006264
Much thanks!
Edited by harmand
17 hours ago, harmand said:
Hi Loren,
CDR-220
Becker 1
Type 4462
48/98
Serial X5006264
Much thanks!
Try 5060
Hi Loren, thanks for your help here.
Showing my car to a prospective buyer and the detailer killed my battery :/
CDR-220
4462
25015111
