  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
3 hours ago, Exercise Your Rights said:
Do you have another code to try?
Thank you
If that did not work there are really only two other possibilities:
  • the serial number you gave me is incorrect
  • The radio has been repaired by a third party (not Becker) so the new serial number generated was not reset properly.
Sorry...
Sorry...
Sorry...
thanks
4 hours ago, Loren said:
Try 0765
Will do. Currently it’s stuck on a wait screen. Guess I have to take the car for a drive for an hour before trying again right?
Hi all,
If anyone could assist with providing a radio unlock code that would be massively appreciated! My details are as follows:
1999 Carrera 4
Becker 1
CDR-220
CDP2081
4462
24/99
SER: Y5034773
Thanks in advance!
Edited by Mikey Snelgar
2 hours ago, Mikey Snelgar said:
Hi all,
1999 Carrera 4
Becker 1
CDR-220
CDP2081
4462
24/99
SER: Y5034773
Thanks in advance!
Try 9101
New on here.  Just bought a 986 and whilst replacing the battery I’ve lost the radio code.
It’s a Becker CDR22
Ser no Y5028520
can anyone help me with this.
thanks in anticipation.
28 minutes ago, Diditg said:
It’s a Becker CDR22
Ser no Y5028520
Try 1570
Hi Loren,
I am hoping you can help with a radio code for my 2002 996.2 C2.
The radio is a Becker CDR-220
Model #4462
Serial #15004879
Thanks for any help you can provide!
9 hours ago, LindgrenC said:
Hi Loren,
Model #4462
Serial #15004879
Try 7018
Local dealer couldn't find code with VIN. Can some help me with radio + nav?
Becker
BE 2580
4514xxxx
Siemens
PO815016xxxx
Edited by rdlg
2 hours ago, rdlg said:
Local dealer couldn't find code with VIN. Can some help me with 996 radio + nav?
Becker
BE 2580
45142443
Siemens
PO8150169844/01
You didn't read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Hi Loren,
I am hoping you can help with a radio code for my 2002 996.2 C4s.
Model #4462
Serial #15002040
7 hours ago, G30 BR0 said:
Hi Loren,
Model #4462
Serial #15002040
Try 9125
Hi all,
I am super glad this is still active! Just recently had my battery die completely so upon getting a new one I am now left needing my radio code.
2001 911 Turbo
CDR-220
Type: 4462
Serial #: y5036632
Thank you for the help! Lifesaver of a forum.
13 hours ago, ItsBasicallyStock said:
Hi all,
2001 911 Turbo
CDR-220
Type: 4462
Serial #: y5036632
Try 9501
