Need A Copy Of The Fuse Plan For An 02.
it's not on the inside of my fuse panel cover. my windows stopped working today and i have no idea which fuse it is. any idea where i can get a copy of that fuse plan. it's not in the owner's manual either.
Edited by deputydog95
The fuse info you're looking for is not in the owner's manual but in the fuse box cover. Pull the cover off and a small booklet should be folded up and stowed on the back of the cover. If it isn't, the fuse you are looking for is D-1. It's A 30 Amp fuse and you'll need a flash light to see the letters and numbers. It's set up like the You Sunk My Battleship game board, somewhat. Good luck. :thumbup:
Edited by WARDHOG
thanks man. i got bored and pulled them all till i found it :)
you were right. d1 was it.
the fuse plan wasn't there for some reason. any idea where i can get a copy of one. i really need to put a copy of this back in the fuse panel or in my glovebox.
any clue as to why the window fuse would blow? i don't think i've ever blown a fuse in any car i've ever owned. i wasn't even putting the window down when it happened. i went to close the door and heard a thump. ouch. that was the window not dipping down to fit in the upper door sill.
  • 4 months later...
