Topping off Oil
Thinking I may need to top off my oil but wanted to check first on how to do it. Is it as simple as unscrewing the Oil Filler cap and pouring it in? Or do I insert a funnel and pour it down? Any help is greatly appreciated.
Also if dipstick reads max on a hot engine, but electronic indicator reads in the middle (+/- 2 bars), do I let it be? This is on a 01 996C2.
It does not matter either method will work fine.
Porsche believes the electronic method is accurate - witness the newer cars don't have the dipstick anymore.
I usually measure the oil after it warm using the graphic display on the cluster. I would only add oil if you have one or two bars showing - and then I would only add 1/2 liter (or 1/2 quart).
