OBD codes 1123 1125
P1123 - Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold
P1125 - Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold
Fuel/air mixture is so rich that sensing is up to its lean threshold. Which means you are running too rich.
The manual lists probable causes as:
- Fuel pressure too high.
- Fuel injector leaking.
- EVAP canister purge valve open.
  • 4 years later...
