Stablilizer Bar (Bushing)?
I have a 2000 C2 and am looking to replace the stabilizer bar bushing? I believe I have the std bar
996 333 792 26. How can I confirm the thickness before buying part?
Loren, thanks! I just got home and borrowed a digital caliper from work and the measurement is 18.7mm, just like you said. I am going to replace the two in the rear. I got confused because a repair manual (Mitchell stated that the std bar uses 20.8mm.) didn't think it was right. Figured you would know. Greatly appreciate it. Also, is it true that the sport susp. has a thinner bar?
Do you recommend changing both, not just one? Is it difficult?
Edited by mdillian3690
Loren,
Torque wrench cheap to get? Can I just buy a basic one? Do I need 1/2 or 3/8? Thanks!
3/8 should be fine. Sears has some good ones. I have one torque wrench I use on engine parts (a nice but expensive Proto Tools) and a cheaper one I use for wheels and body/suspension parts (Sears). Never drop a torque wrench - cheap or expensive.
For this project you could likely get by without one - just don't over tighten the bolts or they may snap off.
Loren, I just received the new bushings for the rear. What is the best way to install them on the stabilizer bar?
