Here's what happened. Had my Porsche battery maintainer plugged into the cigarette lighter. Realized one of the windows was down. Put the key in the ignition and turned the ignition on but didn't start the engine. Put the window up. Turned the ignition off. Now I have a "System Fault - Take car to Workshop" message. Have driven the car 3 times and everything works fine. The idiot light will go out for 5 seconds or so but comes back on.
So what have I done and what do I do? Have a DE coming up next week and probably can't get to the dealer before then. Should I wait and see if it cancels out with a few more driving cycles? Disconnect the battery for 30 seconds? or borrow an OBD reader?
The car is an 05 987S. 12,000 miles and nary a problem till now.
Any advice appreciated.
Brad in Edmonton
Do the battery disconnect. Make sure you have your radio code (if needed).
Do our radios even have radio codes? Had a "used" PCM2.1 headunit installed w/o a radio code, works fine. Don't recall I got one even for the stock CDR-24.
CDC-23 (and newer) radios do not have radio codes per se. They are coded to the car in the DME and self identify when they are re-attached. If you were to swap radios you would need to re-code your DME for the new radio.
Brad in Edmonton
Did you happen to wax your car around the same time this happened? I waxed mine one day this spring and as I was waxing the front of the car the front hood popped open. I then got the workshop message next time I drove the car. I querried a few Boxster boards and was told the control module located in thre right front fender fried thus prompting the same error message that you got. I took the car to Norden and by golly that's what it was! They cleared the message and I drove the car for about a month. In fact I just had the module replaced last Friday. (By the way I live in Lloydminster and have an 05 Guards Red S). I think we have met somewhere at one of the events. Were you autocrossing this past weekend?
DaleE
Dale
Yes- That was me you met at Norden. You must be a mind reader! I had been detailing and waxing my car. No problems and then this message came up. Also the fault message goes out and I lose all my dash lighting when I turn on the signal lights. Turn off the signal and the fault light comes back up and the dash lights come back on. Talked with Gord and he said he'd replaced a few front control modules. I'm driving the car as is till I can get it in.
AX is going well the R-compound tires make a big difference. Going for a DE at Race City in Calgary this Friday.
Take care.
Brad Friedrick
