Can someone tell me how I can remove the back cushion of the rear seat... I removed the bottom cushion and want to remove the rear as well to make some more space for a booster seat
2003 996 Cab
Remove the plastic covers from the pivot points and then remove the bolts.
The plastics covers on the inside or on the outside? Tried taking the inside cover off, but wasn't sure how to do it... force, or is there a more subtle way?
I now see ahat to do, but it looks like the bolt (nr 7) on your schemeatic has some 'strange' kind of head (not philips, etc). Do you know what this is and how/where can I get the correct tool to unscrew it? thx!
  • 3 months later...
  • 6 months later...
I was trying to remove the plastic cover at the pivot points (item #9) but had differcult. Does anyone know how the plastic cover hold to #12?
EDIT: I got it. It is just push in and clips on the the rod. I just need to force and pull it forward.
Edited by gchu
Where I can find a complete part # for this picture of the back seats, I need some parts.. :)
jose
