All Activity
This stream auto-updates
  1. Yesterday
  2. Hello everyone, pleasure to meet you all. I’m experiencing a similar issue that started with my battery running low, which then triggered the 4x4 warning message on the screen. I replaced the battery, but I have not yet replaced the transfer case solenoid actuator (part number PAB341601KT1). I also noticed that on my cluster display, the gear indicator (D1, D2, D3, etc.) no longer shows correctly. The SUV runs fine overall, and I haven’t experienced problems with the gear lever getting stuck, the key being affected (locked)or going in to limp mode, However, the display is inaccurate — for example, when I shift into Reverse, it still shows “D” instead of “R.” When I shift into **Park, it continues to display “D” until I turn off the SUV, at which point it resets to “P.” I scanned the vehicle and retrieved code 1316 – Tiptronic Switch using my X-Tool scanner. I can clear the code, but it returns again after driving. so you only see the D on the display. From my side, I plan to replace the transfer case solenoid actuator soon. In the meantime, I’d like to ask: What solutions have you found for this issue on your end? please keep me posted
  3. you can remove the one that holds the ground wire on the valve cover and then match at Home Depot.
  4. An acquaintance want to sell his 5 month old whites/red GTS cabriolet PDK (kid coming). He paid $189k for it . 2k miles on it. What is a fair price for it?
  5. Hello, I have a 1997 986 Boxster. Unfortunately water got into the immobiliser box under the passenger seat. I then went down the route of buying a new replacement set from a breaker car including ecu immobiliser and transponder pill. The new set works perfectly fine eg the car starts, electronics, and roof works fine, However with the new immobiliser set the passenger door lock refuses to open when I use the key in the drivers door barrel. I have tried putting the key in the ingition then pressing the red central locking button on the dashboard but this still does not open the door. The door doesn't open with the outside handle or the inside handle. To rule out the new immobiliser being faulty i bought another set from ebay however the 2nd new set also has exactly the same problem. The only solution to get the passenger door open is to put my original immobiliser in which allows the door to be unlocked when i use my key in the drivers door barrel, However this immobiliser does not start the car. Hopefully you can see the issue, with my new immoboliser set I cant lock the car otherwise i wont be able to open the passenger door unless i put the original Immobiliser back in. Massive pain so far now i have unplugged the door lock so the passenger door wont lock by accident however this stops the microswitches in the handles working so the window no longer drops when opening the door. So hoping to find a long term fix. Anyone who has changed their immobiliser ecu and transponder key had a similar issue? Hopefully im just missing something. As far as i know the doors arent coded? Thank you in advance.
  6. I'm at my wit's end troubleshooting my 2001 996TT. The car has been a long time project; 4 years on the jack stands. I have modified it quite a bit. Most recently I ran into issues loading a new tune onto the car (Cobb Accessport) which I think may have started all of my issues but I cannot pinpoint that as the root cause. At some point during the flash, the Accessport displayed a "Cannot communicate with ECU" error. The file loads properly on the Accessport, and I can install/uninstall the Accessport to the car, but in either state (installed/uninstalled) the car will crank but not run. Electrical Modifications of Interest: - OEM fuel pump relay output is now a signal wire for a dedicated relay off the battery to feed the Walbro 525lph pump - Injector Dynamics 1300cc injectors Symptoms: - Car cranks, but does not run - No CEL or codes on the DME - I have a passive fault at the instrument cluster for DME signal - No fuel pump prime when ignition turned to On position What I have Tried: - I cannot start the car with the Cobb Accessport installed/uninstalled. It is currently uninstalled while I diagnose - I can fire the fuel pump from Durametric/PIWIS - I can communicate with all modules on the car in PIWIS - I have all IPAS codes so I programmed the DME; still same result - Bench tested fuel pump relay, DME relay, and MFI relay; all tested good I have 2X VALs available but they are 7MB each so I cannot attach; one from before the DME reprogramming and one from after. Hoping someone can help point me in the right direction on what to look at next, because I'm almost ready to throw a standalone on the car (emissions exempt in 2026).
  7. Hi guys, Have a 2000 Carrera Cabrio. When I got the car, it came with an aftermarket Alpine that didn't really work well, so never used it much, so not sure if this is an older issue or a new one. Replaced it last weekend with a Blaupunkt Liverpool series head unit - which is a budget unit I have to admit. It uses the stock M490 amplifier to power the speakers. The sound quality coming out of the speakers is pretty good, but there's definitely some noise (crackling / hum) from the amplifier when the unit powers on and whining sound as engine revs pick up, which is a grounding issue somewhere in the system as it's picking up the alternator. From my research, it seems like in a stock setup, the grounding for the original CD220 head unit and the amp are linked together - so the harness/CD220 has a grounding connection, not sure where. After all this splicing, etc, I'm not sure if that's been lost somehow. In my testing, even with volume set at zero, there is the noise and whine, making me assume it's the amp that needs grounding. Firstly, is this the correct assumption? The noise stays the same volume as far as I can tell when I crank up the volume on the head unit. If I do need to ground the amp and looking at the wiring diagram, I really can't figure out which wire from the blue plug (cause I have a cabrio) that goes into the amp that I should use to create a new grounding connection closer to the amp (I saw a grounding screw just behind the amp).
  8. Last week
  9. I've been trying to get the key FOB to lock/unlock the '98 Boxter I bought in June 2025. Even though the red LED illuminates when I depress either of the 2 buttons (doors & front trunk), I replaced the battery anyway, along with a new top cover for the FOB. Neither function works as intended, but I noticed the red LED on the dash does illuminate in a flashing manner. However, I have to unlock the door manually with the key for the dash LED to extinguish. I've read a lot of threads on several different forums amd watch some youtube videos, but none of the recommendations suggested have proven successful. I have been locking and unlocking the car with the key in the door lock and I'm OK with that, but it would be nice if I could get the FOB to work.
  10. Hey guys so I posted a post last week regarding some concerning sounds that my Porsche 986 from 1996 has and I was looking for a bit of advice. It’s had a lot of work done to it but ultimately isn’t a daily drive so has been sat around for weeks at a time in a Locked garage undercover It’s had new suspension, new cam belt, new break pipes, new starter motor and a new battery but this noise is worrying me I’ve been putting some fuel cleaner in her and running her quite a bit as a daily runner to try and help but I’d just like some advice before I take her in On a cold start this is the sound it makes and when I rev the engine at a low gear or a neutral it seems to make this kind of gargling sound. I was looking for some advice before I take her to the garage so I can know what to expect any answers that would be greatly appreciated. Ive linked to my Facebook post so see if anybody attached are 2 video of the cold start and some revs to show the sounds and issues any help would be greatly appreciated guys as I’m getting no help on other forums video one : video two:
  11. Hi all, I dropped the bolt that goes in the valve cover and holds part of the wiring harness while taking it off and lost it to the abyss unfortunately. Does anyone happen to know the part number or thread size for this bolt? This is for a 2007 957 4.8L V8 Cayenne S. I have looked all over but cannot for the life of me find it. Much appreciated!
  12. It worked! Thank you very much!
  13. Try 5820
  14. Welcome to RennTech The factory radio had a ground wire that had to be attached to the car's chassis under the dash as a simple anti theft device. If that ground is not there, the immobilizer will prevent the car from starting.
  15. Hi all, I am also in need of a code for my Radio CDR 22 Model: BE6621 Serial Number: 25009627 Thank you very much!
  16. Awesome, Loren - that did the trick. Made sure to jot in down for future reference Thank you ... ... Mark
  17. That sounds like an immobilizer issue. Someone with more extensive knowledge will probably step in here with more information. Do you have a repair manual for the car?
  18. Hi guys new to the forum.. My stepson picked up a '99 boxster and the guy said it won't start ever since the radio was stolen. We've checked all the relays. We've got spark to the spark plugs. The fuel pump will work if I bypass it but we can't get power to the fuel pump. Any suggestions? Thank you in advance
  19. Try 7069
  20. Put new pads, rotors, and hardware in on the stock brake setup in my '21 Cayenne E-hybrid and I've got a bit of dragging, most noticeably in corners. I've only driven about 10 miles and did a bunch of hard stops to try and break everything in. Going straight down the road everything seems okay, but in corners I can hear them dragging pretty bad. Thoughts? Where'd I likely screw up?
  21. Hello all ... I recently bought a '98 Boxter, but unfortunately, didn't receive the owner's manual or any other documentation other than the title. I disconnected the battery to install a new one, and apparently the radio lost function that's now asking for a 4-digit code. I read about the issue on several other Porsche forums, but just saw a post on the 986 forum that someone mentioned contacting Loren to access the code. Loren suggested that I post the pertinent info in this thread, so here goes: The radio is a CR-210, Model No. BE2182, Serial No. V5006421 It'd be great if you might possibly be able to help with the issue? Thanks ... ... Mark
  22. Thank you Loren! It works perfectly
  23. Try 1451
  24. Glass strut is smaller that the hatch strut. This is the small one.
  1. Load more activity
