Leaderboard
Popular Content
Showing content with the highest reputation on 09/10/2019 in all areas
  1. You need to look behind the water pump at the engine case wall.
    1 point
  2. I believe the Gates pump has a metal impeller: I am concerned that the pump was replaced because of overheating, not because the pump had failed or was making noise. The question is why was it overheating? At this juncture, if the car was in my shop, I would pull the water pump and look at both the impeller and the wall of the engine case. If the case is tore up, you are chasing your tail trying to get the system to work. As for the reviews of the pump, some "complain" the impeller is composite, others complain it is metal, so it sounds like they could go either way. In any case, we ONLY use the factory water pumps, which are all composite impellers, and work well, unlike several aftermarket brands we have looked at. Unfortunately, many aftermarket bits for Porsches are really junk; water pumps, surge tanks, and AOS units are great examples of what not to buy. We have seen several fail right out of the box. Yes, they are a few bucks cheaper, but after some people have gone through two or three units in quick succession, that few bucks looks like a really bad deal...…..
    1 point
