Leaderboard
Popular Content
Showing content with the highest reputation on 02/21/2026 in all areas
  1. At the end of the day, it is your car and your money. Just be aware that there always has been a limit as to how cold an automotive AC can be allowed to get; some manufacturers actually set a minimum permissible temperature for their system in order to prevent some rather strange problems. We actually had a customer that complained his system seemed to be cooling fine and then would just shut off for no apparent reason during a rather warm and humid period. After some intense diagnostics, we discovered that his system was getting so cold (very low 30F air temps), that under some humidity conditions, the car was actually freezing over the inside heat exchanger, blocking air low until it defrosted, giving the appearance that the AC had quit. We traced the problem to an AC compressor replacement prior to his purchase of the vehicle, where the wrong part number compressor was installed that had a higher capacity rating than the factory unit. We evacuated the system, replace the compressor with the correct part number, recharged the system and found the air temps inside the car's ductwork now stayed at around 41F, one degree above the manufacture's minimum allowable internal air temp. The car never froze up again. While getting you system's AC temps as low as possible seems like a worth goal, sometimes the law of unintended consequences rears its ugly head............
    1 point
