Leaderboard
Popular Content
Showing content with the highest reputation on 05/13/2026 in all areas
  1. P0441 code is EVAP purge valve, alongside the drive side intake manifold tubes. P2281 Code is most likely an air leak between the MAF and the throttle body, the code generally means that the powertrain control module (PCM) has detected a degree of airflow at the mass airflow (MAF) sensor which does not exist at the throttle body.
    1 point
