Leaderboard
Popular Content
Showing content with the highest reputation on 09/03/2026 in all areas
  1. Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. (Special thanks to Chuck Jones for being the guinea pig and for taking the photos.) Parts you will need: 997.624.113.00 Actuator Tools you will need: Very short Torx T20 driver and right angle ratchet or tool to use the short T20 in a very confined space Regular screwdriver, phillips screw driver, and 10 mm wrench to remove th wheel well liner 1. Jack the car so that right front wheel is off the ground and secure it with a jack stand. Remove the right front wheel. 2. Remove the wheel well liner by removing the the plastics rivets (pry them out with a regular screwdriver). As well remove the 10 mm nuts on each side of the axle. Now remove the phillips screws that fasten the wheel well liner under the front bumper and remove the wheel well liner (and set aside). 3. Locate the EVAP canister and remove the electrical connection at the top of the canister. Now remove the 10 mm nut that holds the canister in place. Remove gas the vapor lines - one at the top and one at the bottom (again by squeezing the connectors). Remove the EVAP canister by pulling gently back and forth until it releases from the rubber gromments 4. Look back up under the fender (now that the canister is out of the way) and locate the broken actuator. Now using the stubby Torx T-20 loose (but do not remove) the two T-20 screws. The actuator itself is a bit tough to get to and you will need a really short T-20 Torx head to loosen the two screws. I say loosen because that is all you need to do to remove the part - it sits in two "U" shaped slots. Remove the electrical connector (by squeezing the tab). Here is a pic of the new part - as you see the Torx screws are already in place so that is all you have to do to replace it. 5. Put the new part in place making sure you feed the emergency pull line through the fender to its location in the door jam. There is room to slide it through the side so you don't need to try and thread it through the hole. Fasten the two Torx screws and reconnect the electrical connector. Chuck's car had the guide rose guide piece missing (so he needed to order one) Here is a pic of his car (without guide rose) and my car (with guide rose). Ref. P/N 997.624.505.00 We also noticed that on his car the plastic catch for the lock was missing (so he needed to order that too). Here is a pic of his car (without cap) and my car (with cap). Ref. P/N 996.201.243.00 6. Reinstall the EVAP canister by pushing it into place on the rubber gromments. Then reattach the vapor lines (they should snap back into place) and the electrical connection. Finally put the 10 mm nut back in place and tighten down. 7. Reinstall the wheel well liner (reverse of removal). 8. Mount the tire, lower the car and re-torque the wheel bolts. Done.
    1 point
