  1. 996.351.425.xx and 996.351.426.xx are front calipers (left and right) for a 996. The xx would designate whether the car is a C2 (2WD) or C4 (4WD). 996.352.425.xx and 996.352.425.xx are rear calipers (left and right) for a 996. The xx would designate whether the car is a C2 (2WD) or C4 (4WD). Factory front pads are: 996 352 949 02 Factory rear pads are: 996 352 939 03 The Boxster S uses the same front calipers as a 996 except the are red.
  2. It is more likely a "Workshop Service Action" which is a voluntary service action as opposed to a government "recall". I see if I can get a copy of the workshop service action bulletin.
  3. Are you talking about the "Porsche Child Restraint System". If so what part number did you purchase.
  4. And more Porsche, Penske Motorsports To Run Together With New Prototype In American Le Mans Series
  5. I removed mine (both screens) 3 years ago. I disconnected the battery at the time and had the DME relearn the air flow. Zero problems.
  6. 000-044-500-28 is a 10 mm RoW sport kit for a (coupe, 4WD, 6 speed). I think the MY02 C4S must be different. This the MY03 C4S page from the (Feb 2005) RoW tequipment parts list:
  7. The factory side skirts used in the narrow body Aerokits were all the same from MY01 on. I think the parts kits only come with the complete aerokit package - so you will need to order them too. 996 559 983 04 Left sill cover (in primer w/double stick tape) 996 559 984 04 Right sill cover (in primer w/double stick tape) Two parts kits 000 044 801 65 Various bolts and nuts
  8. Wow! Did the flywheel bolts perhaps come loose and the timing ring hit something (as it wobbled)?
  9. 1. No this is an RoW 20 mm lowering kit. All parts for the X73 package are marked X73 in the parts list. 2. There is a left and right front strut in that kit.
  10. It is hard to say what the differences are in the later ones. Could be just a vendor change. No one has ever proven any performance differences with any of them even over stock.
  11. :lol: ... no need to Google it it's right here
  12. The difference (I believe) is between the standard power steering and the optional (Option 1N3) Variable Assist Power Steering - Servotronic speed sensitive power steering. This shows as available on all Cayenne models.
  13. Item 27: 996 701 801 00 Left spacer retail $0.89 996 701 802 00 Right spacer retail $0.89
  14. Tell us which items numbers you need (I assumed a US car but you didn't say).
  15. I am not sure what the "SM" code (next to your paint code) stands for on your code tag. For instance my car has a Boxster Red interior and the code on my tag is "MA". Perhaps someone else here knows?
  16. :oops: forgot the X45 X45 - Instrument dials in interior color Sorry, I meant a pic of the interior. Is there more than one color used or special order trim? A pic would really help
  17. XRB - 18" Sport Classic 2 Wheels 236 - 18" Tires 689 - Prep for CD Changer 695 - CD Radio CDR 22 I have no idea what SM refers to. Do you have a pic?
  18. Yes, 000 044 200 21 will work on either a 3.4 or 3.6 liter car.
  19. Yes, 04 replaced the 03. The 03 is no longer available to order. I haven't seen one yet. Speculation would lead one to believe there was a vendor/design change when they did 997 PSE. The 997 exhaust is supposed to made of thin wall tubing and also supposed to be lighter. Perhaps they applied that to the new 996 mufflers? We can only hope...
  20. The sensors are the same for all conventional (steel) brake systems on the 986, 996, GT3 and TT. Not the GT2 or any of PCCB brakes. The new cars 987 and 997 use same but different sensor also. Same holds true for the sport and PCCB brakes on the new models - yet a different sensor.
  21. If you want the light to go out - yes. The sensor is just a wire that when worn through creates an open circuit - turning the light on. If you check your pads often (you should since you track the car) then you could just use a wire to bypass the sensor and then use a tie-wrap to hold the wires away from the brakes/wheels. Most performance pads do not have the holes for the sensors anyway.
  22. :oops: only Contributing Members can view TSBs online. I sent you a PM.
  23. Have a look at TSB 3/00 7059 Noises In The Door/Door Trim Panel Area (dated 6-30-00). It is likely one of the items below (all are covered in this 7 page TSB). Complaint 1: Rattling and knocking noises from the entire door area (left or right side). Complaint 2: Creaking noises from the front or rear of the door area (left or right side). Complaint 3: Clicking/crackling from the area of the side airbag. Complaint 4: Creaking in the area of the inner door release. Complaint 5: Grating from the door lock. Complaint 6: Clicking from the area of the inner door (power window).
