  1. Durametric Pro simply allows you to use the software on more than 3 vehicles. All functions are the same.
  2. Try 0438
  3. IMHO I would stay away from AGM batteries on the older cars. Any conventional battery should get you 4 to 5 years - nothing is better regardless of cost.
  4. Try 4601
  5. Exact model and year of your car please? And... front or rear trunk?
  6. Try 3106
  7. I see no reason a KTS 550 would not work as it is just an enhanced version of the KTS 520 - which does work. Of course you would need the proper OBD II cable and software.
  8. Try 4925
  9. Try 4654
  10. If your car has option I2D4 then it is a GTS with aerokit. Do you have your option codes?
  11. 955-505-513-10 if the car is without aerokit -- US MSRP $211.22 955-505-513-11 if the car is with aerokit -- US MSRP $349.14 Both come primed and ready for painting.
  12. I would start with a cleaning of the throttle body and butterfly. The egas engine are very sensitive to carbon and dirt build-up on the butterfly and small idle ports in the throttle body housing. Do a search here for more tips on that - and it is likely easier with better results if you remove the throttle body and clean it with carb cleaner (or fuel injector cleaner. The light smoke at startup is likely normal.
  13. The larger rear bumperettes came out in 1976 (I had a 76 911S). Likewise with the side view mirror - 74 and 75 had the smaller chrome ones (at least in the US they did). I agree a "mixed" version for sure.
  14. Yes, you post photos and any other information that might help folks give useful advice.
  15. 1974 ushed in the 2.7 liter engine and they only sold the 911and the 911S. So no 911T in 1974. Cars that are older usually require more scrutiny as engines, transmissions, etc. were easily swapped out. http://www.caranddriver.com/comparisons/1974-porsche-911-vs-911s-targa-911s-carrera-archived-comparison-test
  16. Just disconnect the stainless steel vacuum line from each muffler -- rotate and drop down. The rear wheels need to be off the car.
  17. Try 8607
  18. Try 1087
  19. Send me a PM please...
  20. Yes, 999.170.207.91 Spark Plug (14FGR 6KQU) is still the correct Porsche part number. Bosch, Beru, NGK should all work as long as they are the same size, thread depth, and heat range.
  21. Try 0482
  22. Try 4243
