  1. Try 2470
  2. Try 1083
  3. Try 0152
  4. Try 5062
  5. Try 9345
  6. 996 631 149 00 Ventilation component -- US MSRP $21.76 each
  7. 999 500 078 00 Speed Nut -- US MSRP $4.55 each
  8. No such thing as "warped rotors". Chances are your pads overheated and they have left deposits on the rotors (as well as ruined the pads). You should really change to track pads for the track and street pads for the street. You will likely need new pads and cleaning/light turning of the rotor discs.
  9. Check pages 4 to 8 of this SmartTop install manual - you will see (in the photos) how to get to the relay panel and the relays. mods4cars product manual.pdf
  10. There are two relays for the spoiler - once retracts and other extends. You could swap those (since they are the same) to see if one is the problem. They relay 3 and 9 on the relay panel behind the top panel (service position). If that makes no difference then you are likely down to a broken wire in the spoiler or a bad microswitch in the spoiler mechanism.
  11. Try 9376
  12. Try 3438
  13. Try 1035
  14. Try 7320
  15. Try 8301
  16. http://www.renntech.org/forums/topic/15633-brakes-not-releasing-sticking/?p=79485
  17. Some of the early model 1999 cars also had problems with a leaky seal at the brake booster. If the seal leaks you get water into the booster and that causes all kinds of abnormal brake behavior. I would check the TSB and then check the brake booster too.
  18. Try 9396
  19. Try 2394
  20. Try 1032
  21. Try 2679
  22. Odd that your's is different as I just got those instructions from Porsche's PIWIS TSI today - and they were specifically for a 2009 Cayenne V6.
  23. :welcome: I have moved your topic to the proper forum. I think you are likely missing the fiber optic connector. You may also need to have the Most programmed for the new CD Changer. Some cars came pre-programmed and some did not. There is a 15 page Porsche TSB that describes the whole process - and it is available here to our Contributing Members.
