  1. Try 1208
  2. Try 9532
  3. Perhaps the Speed gong is set on your car as the spoiler (working or not) does not generate any beeps.
  4. Try 4394
  5. Arena Red Pearl (97-99) / Arena Red Metallic (00 on) Water-based paints (84S) and Conventional paints (84R). US/Canada cars all got water-based paint (per EPA rules).
  6. Try 9082
  7. Try 8764
  8. Try 0623
  9. Obviously you did not read the Lost Radio Code FAQ did you... ;)
  10. Try 5871
  11. Please read the Lost Radio Code FAQ What is the model number of your radio?
  12. Try 9879
  13. What is your front wheel width and offset?
  14. I have not seen the prep TSB for 2015 models - it is not yet showing up in PIWIS TSI. In the past some hardware and programming were both required.
  15. Try 0215
  16. Yes, this option can likely be added via PIWIS 2 - but Porsche requires that the dealer/OPC get the authorization directly from Porsche - after proof of purchase. They do this to prevent dealers/OPCs from giving options away for free.
  17. This is the 2nd radio code you have requested a code for in the last month - perhaps you should consider a donation to this site.
  18. Thank you. Try 1049
  19. This is the 3rd radio code you have requested a code for in the last two months - perhaps you should consider a donation to this site.
  20. Shock/strut perhaps also on bump rebound.
  21. Most 240's will rub slightly at full lock... depending on your wheel manufacturer and tire. It's a tough call with a taller wheel - you might have to experiment. I run a 235/40 on an 8 inch x 18 inch wheel and it just barely clears.
  22. Those fronts will rub - pretty much guaranteed.
  23. Small amounts of air well self bleed but not gross air pockets. Plus you run the risk trapped air causing severe hot spots that can do damage.
  24. Sounds like you need a new battery. All kinds of strange things happen in modern computer driven cars when the battery is low or weak. I would start with a new battery.
  25. I would have a good look at the swaybar bushings - they wear out too.
