  1. Try 6543
  2. Try 8438
  3. Sorry, we only have codes for Porsche radios.
  4. Try 4524
  5. Try 0304
  6. Try 6754
  7. Try 5427
  8. Try 2105
  9. Try 9154
  10. Try 6940
  11. Yes, that should not be a problem.
  12. Try 0981
  13. The photos were posted on an external server - the owner may have deleted them or unsubscribed from the service.
  14. A common is on the 9x6 cars is foam liner from the HVAC flaps getting into the blower motor. If enough gets in there it can cause motor to stall and/or fail.
  15. Those may or may not have the proper part numbers as they are old printouts. (The two I looked at were July of 2017). We (RennTech.org) have access to the same up-to-date parts list the dealers/OPC have.
  16. The number one cause of strange electrical issues is a weak battery or poor grounds. The is a service bulletin for bad cables from the battery to the main power distribution.
  17. Exact mode and year of the car please. Does the car have PASM? How old is the battery and has it been load tested?
  18. Try 1247
  19. Sorry, I wasn't sure it would work on such an old radio.
  20. That is a very old radio, so I hope this works for you. Try 7023
  21. Try 9432
  22. I doubt you can change the speed without hacking the code. Many issues can be fixed by re-programming the control module.
  23. There is a combination of plastic clips (which may break on removal) and double-sided tape. Use a heat gun to warm (just warm not hot) the panel then lift with plastic trim tools.
