  1. Hi there Lauren, I am very sorry to bother you on my first day, but I was also able to locate my Engine Tranny Code, I would appriciate anything you could tell me about it. Mine is also a 2005 996 TurboS but with Tiptronic S transmission and Cabriolet. My number reads as M9670-645 A9650-10... Thanks... Devrim Uh... it's "Loren" M9670-645 is a 360 KW (or about 483 HP). A9650-10 is a 5 speed Tiptronic transmission
  2. Where are you located and who is the dealer. The tech is supposed to do a measurement on the seal bore after removing the leaking seal - if it does not meet factory specs then they are supposed to replace the motor -- period. It would also be worth asking if the they used the newest seal last time - it would start with a 997.xxx.xxx.xx part number.
  3. Go back and look at the insulators on the coil packs. My guess is that one of more is cracked.
  4. Are those from an order guide? Because they are not found on the car. Look under your front hood for a sticker with the option codes the car shipped with. Most should start with M or I.
  5. For legal reasons you are allowed read but not copy, print or distribute the TSBs.
  6. You will need to contact your regional Porsche AG representative. If you don't know them then you will need to contact Porsche AG in Germany. In the US and Europe you do not buy the PIWIS tester - you lease it from Porsche.
  7. All you are doing is pushing the pistons back in (slowly and carefully) so that new pads will fit into the calipers. This action will push brake fluid back into the brake fluid reservoir (in the front trunk) - so you need to be careful that it does not overflow. Unless you have a bad piston seal there should be no reason to bleed the brakes after a pad change. Once you are done and ready to drive the car - start the car and press the brake pedal several times to seat the new pads. follow the pad manufactures recommendations for "bedding in" the new pads.
  8. Do you have any lights (airbag) or other problems? If not, I would double check with the folks at Durametric. Could be Porsche did an update they are not aware of...
  9. Can you get a pic of it and post it?
  10. That is why I have a metal one. Sometimes in one of our work on cars days we see oil filters (and drain plugs) that are way over torqued.
  11. Sounds like it has lost it's tension. As I recall when it is installed they wind up a tensioning spring. Does the motor run?
  12. Yes, that is a US part number - you can see the retail price here in the US Retail Price lookup. (Contributing Members only)
  13. German cars? Not really true. On Porsche's the cigarette lighter is always hot (unswitched +12 volts) - so theoretically you could put enough draw there to bring the battery down over time. It will depend on how much current for how long. On my Mercedes the cigarette lighter is switched so it is off when you turn the key off. There is good and bad to both - on the Porsche you can use the battery maintainer through the cigarette lighter but if you left something else plugged in you could cause a drain. On the Mercedes you can't charge the battery through the cigarette lighter nor could you cause a drain. I personally prefer the Porsche method.
  14. We have been able to find and acquire a fairly good number number of older and missing TSBs for most all models. These include some Campaign TSBs (including recalls), Workshop Service Action TSBs, and quite a few Cayenne Quality Improvement Workshop Campaign TSBs . We have added and/or updated TSBs in the following categories today (131 total): Boxster (986) - 26 Boxster (987) - 4 Carrera (996) - 28 Carrera (997) - 3 Cayenne - 34 TT (996) - 32 CGT - 4
  15. Not bad! MSRP is $629 from Porsche (and yes that is an exchange price)
  16. What was Autozone's price for the alternator?
  17. 100 C or F? 100 C is too hot. You should check and clean your front radiators. Also, check you coolant tank and make sure it is full and not leaking.
  18. As long as the CEL is not flashing it is okay to drive the car (as long as it runs ok). They have to find the problem before any parts/labor estimates. If you had a P1123 (cylinders 1-3) also then I would say a dirty MAF - but since it is only on one side they need to look at the DME readings to tell if the MAF is working right.
  19. P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold This means that mixture on cylinders 3-6 is too rich and the DME can not correct for it. Potential causes are: - Fuel pressure too high. - Fuel injector leaking. - EVAP canister purge valve open. Since you just bought the car I would go back and make them fix it.
  20. That is the correct operation. The function of the purge fan is to pull cool air into the engine compartment. The fan should should come on very rarely. http://www.renntech.org/forums/index.php?s...ost&p=72289
  21. 996.512.250.00 Rear spoiler wall -- MSRP $80.19 (as of June 2007)
  22. 996.561.787.00.01C Cover cap I haven't tried to replace one - perhaps someone else here has and can help.
  23. http://www.renntech.org/forums/index.php?s...ost&p=54716
  24. Try 9495 or 9497
  25. Porsche says not to. I believe the internal tubing diameter is small on the 3.4 mufflers.
