  1. Hmm... so your problem was within one of a fill up?
  2. Just so we can rule it our... when did you last fill up with gas?
  3. Perhaps we can find a member with a PST2 or Durametric Software to see what the actual values of some of the sensors are.
  4. I couldn't find a section on that in the 993 service manual. Perhaps this parts diagram will help.
  5. It's pretty simple. Once the two screws are out you lift the ash tray out and remove wire from the light and press the switches out (remember which one goes on which side). Then to install put the switches in one at a time making sure that they snap into place. Since there is no light in the new non-smoker tray you just leave the wire from the ash tray light unplugged (but out of the way). Put the two screws in and the rubber mat and you are done.
  6. I would start by looking for a loose front swaybar mounts. Those are fairly common. Next I would check the shock tower bolts.
  7. In the US OPC is the dealership. The dealer can reset the counter and erase the message (with their PIWIS tester).
  8. Hmm... never noticed that before. Likely a misprint because I know folks have ordered this kit and gotten everything they need.
  9. Yes, I don't see this as useful Porsche content - so I am closing this thread.
  10. That is the correct part number. Since it is a "kit" there is always the chance that one or parts is holding up the order. Here is itemized list:
  11. For folks wanting to do this... Chuck Jones and I did the latch replacement today and Chuck shot a bunch of pictures. I will post a DIY with pics soon. Nothing really to hard here. The canister comes out with a little wiggling (disconnect the vent and electrical lines first). The actuator itself is a bit tough to get to and you will need a really short T-20 Torx head to loosen the two screws. I say loosen because that is all you need to do to remove the part - it sits in two "U" shaped slots. BTW... Chuck's alarm problem was not the actuator - he has a bad front hood microswitch (thanks to my trusty PST).
  12. I'm pretty sure it is the same radiator but in the RS the radiator is tilted the opposite direction and the ducts are different.
  13. Ah... If you look at the $247 package it reads "Enthusiast Package This package is designed for the Porsche enthusiast that works on there own car. It offers all of the great features as our professional kit but will only work on up to 3 cars." My guess is that too many shops were buying the software and using it - while Durametric got no additional income. Or you bought it and use it on all your friends cars - then they don't need to buy it. Seems fair to me. They have an excellent product - they deserve the money they make.
  14. Then you likely have the wrong type of battery. All batteries vent gases (acid gas). Since this is inside your trunk area you really want a battery with an external vent connection (and that tube connected). http://www.renntech.org/forums/index.php?s...ost&p=14446 I cannot find the vent hole for Interstate MTP-91 - Mega-Tron Plus. http://www.interstatebatteries.com/estore/...nk%7C1&js=1 I have used the battery for 2 months. Am I asking for trouble for continuing to use it? It is right in the center - just like the others. It is that small oval opening. You will need to get the short tube that fits the oval and connect it to your clear tube. I think all of these batteries seem to be made by Johnson Controls.
  15. My guess is that when the MY99 came out they were using different (2 prong electrode) plugs and have since updated to the 4 prong. Then they left it as it was so MY99 owners would still replace their plugs at 30,000 (which they should do if they are the 2 prong plugs). Once you switch over to the 4 prong I see no problem with changing the interval to 60,000. All IMHO of course...
  16. I believe the brakes on the 2S are the same as the (mk2) 996 GT3 - so that would be: Brake disc thickness, new front 34mm rear 28 mm Brake discs minimum thickness front PCCB = 33.5 mm steel = 32.0 mm rear PCCB = 27.5 mm steel = 26.0 mm Thickness tolerance of the brake discs, max. 0.02 mm Lateral runout of the brake disc, max. 0.03 mm Lateral runout of the wheel hub, max. 0.03 mm Lateral runout of the brake disc when installed, max. 0.06 mm
  17. Then you likely have the wrong type of battery. All batteries vent gases (acid gas). Since this is inside your trunk area you really want a battery with an external vent connection (and that tube connected). http://www.renntech.org/forums/index.php?s...ost&p=14446
  18. Factory rotors and calipers or after market?
  19. I can remove the rear center console in about 5 minutes (I done too many B&M short shifter installs -- LOL)
  20. There is no way to do it without removing the rear center console (which is not as hard as you might think). The DIY instructions are here.
  21. :thumbup:
  22. I think you are going to have to drop into a shop and see if someone will let you measure one.
  23. Those will all fit fine. Alcantara is readily available but I think red stiching would be special order. Check them out at: Carnewal.com
