  1. http://www.renntech.org/forums/index.php?showtopic=5611
  2. The preliminary MY06 Order Guides for the Cayenne (V6), Cayenne S and Cayenne Turbo have been updated to FINAL versions. Other models will be added as they become available.
  3. They are using the Targa blind switch - see below:
  4. 997 044 900 80 PCM 2.1 Retrofit Kit for Europe - I show a US retail price of $2601.63 so your country price will vary. The supplying OPC should give you the installation TSB (Technical Service Bulletin) - if they don't then buy it somewhere else.
  5. Try the folks at Sunset Imports (see Porsche Parts at Dealer Cost at the top menu). If you car is a non-turbo 1987 911 then you will need 911 355 011 12 Master cylinder - retail $239.20. I'm sure Sunset Imports has a much better price...
  6. Looks to me like there was a major software revision and that you may not be able to upgrade. If it can be be upgraded then I am sure it can only be done with a dealer PIWIS tester.
  7. XAA - Factory installed Aerokit Cup XRB - 18" Sport Classic 2 Wheels 236 - 18" Tires 376 - Sportseat backrest shell 696 - CD-Radio, Porsche CDR-220
  8. From a June 22nd, 2005 Sales Bulletin:
  9. Scouser... is the bucket part of an elaborate alarm system? :lol: :lol: :lol:
  10. Yes, that is the default setting on your MY car if the OBC has been enables. Otherwise that display would be blank.
  11. XE8 - Gear lever in dark burl walnutr with aluminum inlay XE9 - Handbrake in dark burl walnutr with aluminum inlay 502 - Made in Finland 537 - Seating positon control - comfort seats - left 584 - Storage box behind seats 981 - Leather equipment without seat covers 983 - Seat covers in leather - front
  12. 2004 C4S Cab - North America version C02 - Equipped with catalytic converter XCZ - Switch travel shortening XNR - Central air vent in carbon XNX - Trim strip in carbon XP4 - ??? XSC - Porsche crest embossed in headrest XJ4 - Ignition lock surround in leather X47 - ??? X54 - Stainless Steel Exhaust Pipes X58 - ??? 265 - Automatic anti-dazzle mirror with rain sensor 266 - Automatic anti-dazzle exterior mirror 288 - Headlight washers 342 - Seat heating left/right 375 - Sport seat backrests 09991 - Manufacture from the exclusive-programme
  13. No, I don't but almost everything is T15, T20 or T30. I think T30 is way too big so they are likely T15 or T20. I think Sears sells a nice small set of Torx with screwdriver handles.
  14. Yes, the emergency pull cord for the front hood is behind the right front wheel well. Most shops and dealers know how to get to it. The fuel lid will not open for the same reason - it is electric. The fuel door is locked (and alarmed) when your car is locked.
  15. The stock two-tone horn is on it's own 25A circuit so you could always bump the fuse up a little.
  16. Becker North America Phone mute/Aux audio-in/Tel audio-in/Radio Removal keys in one kit is, BNA-116.276 ($16.40) To order call (888) 423-3537 x1209
  17. Use a charger that works through the lighter and that will likely have enough power to open the front trunk. Later model cars have a similar jumper point on the fuse panel (in the drivers footwell). If all else fails you can use the emergency manual release behind the passenger side headlight. Do a search here if you have trouble finding the emergency release cable.
  18. Very, nice! You do know that you can have multiple pics per message - up to your 250k limit?
  19. C02 - Equipped with catalytic converter 198 - Starter 1.7 kw 232 - 17" tires 249 - Tiptronic transmission 394 - Boxster 17" wheels 432 - Steering wheel with Tiptronic controls 454 - Automatic Speed Control 490 - Sound System (Harmon I think) 502 - Made in Finland 535 - Anti-theft lock 315 mhz 551 - Wind deflector 584 - Storage box behind seats
  20. The US and Canada MY2006 Boxster order guides are not out yet. There is a sales bulletin (from May 2005) that says TPMS will be available on MY2006 997 (option 482) but does not mention 987.
  21. I think the issue is cross-threading.
  22. Here is a link to a small really easy to use FREE program. IrfanView Just go to Image - Image Resize/Resample then set the image size to something like 800 x 600 and set the DPI to 72. Then Save As and you are done.
