  1. The only instruction I have a re for the GT3 Club Sport bar. I think the 4 point bar is the same as the full roll cage (6 point) without the front section. Perhaps they are similar enough to help. I'll send you a PM.
  2. I am aware of that - of course you can add Porsche parts - that is what we help folks with here. When you said aftermarket I assumed you meant non-Porsche parts. In many cases Porsche prohibits their suppliers from re-selling parts or systems designed for Porsche. There have been a few exceptions but I think your best bet is to try a Porsche parts discounter like Sunset Imports (Porsche Parts at Dealer Cost link at the top of the page).
  3. If you are only getting a P1126 then theat would indicate the problem is on the cylinder 4-6 side (passenger side on a Carrera).
  4. You need to state what year, model and current sound system your car is. Some of the later MOST (fiber optic) systems are hard to add on to.
  5. I personally would not touch an RMS that is not leaking. All the other clutch parts are subject to wear but if a seal is dry I would not touch it.
  6. 997 553 118 01 9L4 Leatherette Lateral Cover (right) in black - retail price shows as $0.00 so they will likely have to fax PCNA for a price.
  7. 997 553 118 03 FSA Leather Lateral Cover (right) in black/grey If you have option 981 then this is part number - if not you will need the leatherette version.
  8. Yes, there is a sensor in the engine compartment. Here are the conditions that he fan should come on at.
  9. US order guide? If so, here you go... my03_boxster_s.pdf
  10. I made some comments about those manuals here.
  11. I sent you the instructions...
  12. I think you are referring to the door airbags - and he wants the passenger airbag.
  13. Ready for some bad news? Official Porsche Tech Website $110 per section or $5,200/year
  14. Announcement for New Members and Guests
  15. This will vary depending on the model year. For instance, my 1999 Carrera says to use 15W-50 Mobil 1. There is an official "Approved Oils" TSB from Porsche (that is updated every year) that states Mobil 1 approved oil is 0W-40. That TSB also has 8 pages of approved oils from many companies. Contributing Member can view that TSB (as well as others) here online.
  16. 955 044 900 04 CDC-4 Refrofit Kit for cars without Bose system - retail $881.01 955 044 900 12 CDC-4 Refrofit Kit for cars with Bose system - retail $881.01
  17. Folks... we have a public Reviews section here. If you like a product why not write a short review? Any member can write a review. Thanks!
  18. The part numbers are in the printout I gave you above. I do not know the difference. If you are lucky perhaps a dealer will have both in stock and allow you to compare them.
  19. The printout I gave you above is from the RoW parts list which usually includes all parts used worldwide. I could print it is German if you prefer ;) BTW... the model year 02 (and newer) control is a different part number.
  20. Loose sway bar. Needs to be retightened.
  21. Thanks Loren Can the three plastic rivets that hold the wheel well liner be re used Yes, I have many times. Just be patient when you remove them and don't tear them up. I keep a few spares just in case though.
  22. Looks like the trim piece is either: 996 545 521 04 sealing frame - retail $53.37 or 996 545 545 01 trim frame (to MY01) - retail $62.23 There is not a specific instruction for that piece. From what the manual shows you will need to release and remove the sliding portion of the panel.
  23. 997 653 111 09 FMH Control Part volcano grey/black mat - retail estimate $571.40
  24. Two options: with or without heated seats controls
