  1. Are you asking about the Carrera 996 X51 package? If so, then no the transmission is the same as a standard Carrera (and part numbers vary by year). If you are asking about the TT X50 package. Yes, there is a different transmission. It is still a G96.50 transmission but the X50 gets part number 996 300 010 55 starting in MY02. The standard transmission in the TT is 996 300 010 50. And, there is a version with limited slip (G96.88) that is part number 996 300 020 88.
  2. Uh... could it be that the fronts with the 6 piston calipers have bolts and rears have the older 4 piston calipers with pin and circlip?
  3. We have added complete (Porsche) recommended maintenance schedules in the form of checklists. These lists cover Minor, Major, Annual and Additional maintenance for both USA and RoW cars. They can be found in the Carrera DIY section.
  4. 986 505 553 01 01C Left Grill Frame (satin black) 986 505 554 01 01C Right Grill Frame (satin black)
  5. Hmm... my one month old parts list still shows a spring clip. Only the Carrera GT has a bolt. I certainly wouldn't go over 15 ft-lbs. -- maybe a little Loctite though?
  6. The two caliper attachement bolts are 63 ft-lbs.
  7. The door handle removal on a Carrera is slightly different than on a Boxster (Jeff's link). See the DIY instructions here for a detailed instruction for the Carrera.
  8. I would say about a 2.5 on your scale. Not difficult -- just takes a little time to pull everything away. I think average time is about 1 hour. Have a look at Lou's DIY that's pretty much the job. Not really, but you should look closely at the hoses and clamps. If you catch the coolant (and your container is clean) you can reuse it - but to be on the safe side perhaps a liter of coolant. You will mix that 50-50 with water and 2 liters should be plenty to top up with. I would try Sunset Porsche in Oregon they sell at dealer cost plus 10%.
  9. Okay, the procedure involves replacing the release bearing and arm -- so the transmission will have to come out. What year car? Old PSE (3.4) or newer version? BTW... it is more than electronics you have to install vacuum lines to control the valves. FYI... These items are not in TSBs (Technical Service Bulletins) they are in the service manual. The C pillar unsnap by pulling forward (towards the car interior). The foam piece over the DME can be removed to get access to the rear deck.
  10. C2 Fuel Tank C4/C4S Fuel Tank
  11. (This is for US cars only) oil change - 15,000 miles or once per year brake flush - every 2 years unless the car is tracked - then at least twice per season coolant flush - never unless the system is damaged microfilter - pollen filter? 15,000 miles fuel filter - 30,000 miles air filter - 30,000 miles 4 wheel alignment - inspect every 15,000 miles and align as needed Porsche characterizes these as: Minor Maintenance (every 15,000, 45,000, 75,000, 105,000 miles etc.) Major Maintenance (every 30,000,60,000,90,000,120,000 miles etc.) Annual Maintenance (on vehicles with annual mileages of less than 9,000 miles, an annual maintenance must be carried out once a year) Additional Maintenance (items that have special needs) If you want the detailed listings email me and I will send you the five documents. These are pretty much the same as any car and very much dependant on how the car is driven and the care it has been given.
  12. Your dealer is right. Perhaps this from TSB 9/99 2015 Carrera 4 – Running Out of Fuel (dated 10-14-99) will help.
  13. I sent you the install TSB. Here is a link to the switch wiring change.
  14. In order (IMHO): 4 (to be safe yes) 4 4 4 (depends on whether you do the door pieces -- door pieces 7) 1
  15. 996 106 147 56 (as of October 31, 2003)
  16. Here is a link to where the parts lists are. Be sure and choose the specific equipment you have now to get the correct part numbers. This depends on your skill/tools. Either way the dealer will have to activate (turn on) the CD- Changer with their PST2. If you live in the SF bay area Jeff and I can help you install it. Get your part numbers and shop around. I would suggest Carnewal.com or SunCoast Porsche in Florida or Sunset Porsche in Oregon. See the listing in the linked post.
  17. Doug, Do you already have the electronics installed and you just want the switch? Or do you want to install the whole thing?
  18. The Carrera TSB (5/00 4078 Loose Stabilizer Bar Connection - dated 9-1-01) does not state the torque just that they need to be re-torqued to factory specs. There is not a GT3 TSB for swaybars (at this point in time). Front Stabilizer mount on stabilizer (M10) -- 34 ft-lbs. Rear Stabilizer mount to stabilizer and spring strut (M10) -- 34 ft-lbs., GT3 -- 48 ft-lbs. Rear Stabilizer to carrier side section (M8) -- 17 ft-lbs. Edit - added second torque setting for GT3 only.
  19. Please remember that the AllData/etc. TSBs are from PCNA and may differ slightly for RoW applications. You've got mail...
  20. Well.... I drove Mike's (mds) GT3 a few days ago and I'll have to admit I am tempted. But... I am also tempted to buy a Cupcar... so chances are I'll wait until I feel strongly enough to pull the trigger on one or the other. :huh:
  21. Yes, just open the bleed valve on top of the coolant tank. You can drive around with it that way and it will help purge air out of the system. Just check the level every few days and add coolant/water until it stops going down. Then close the bleed valve.
  22. Yes, that is very abnormal. It turns out that Cayenne suspension does some settling and needs to be re-aligned after about 120 miles. I would see your dealer and request a re-alignment to the new specs laid out in TSB 4495 (and a couple new tires!).
  23. Porsche recommends only: 999 917 547 00 Esso ATF LT 71141 – 20 liter container (an ATF change is only 3.5 liters) with this warning Draining, changing the filter and refilling, warming up and topping off are all required with an ATF change. I'll send you an email and you can see if this is something you want to tackle.
  24. I guess you are talking about the "snorkle" that brings in cool air to the air cleaner. There are two piece to this - the top most piece (sealing bellows) that seals against the engine deck lid (bonnet) and the longer plastic tube. The bellows can be ordered and the longer plastic tube is part of the lower air cleaner assembly and does not have a separate part number (you would need to by a whole new air cleaner assembly). If the crack is not too big I would not worry about it. JMHO
  25. Yes that one is for a creaking noise in the bell housing (behind you) and there is another one for creaking noises at the pedal. I'll send both.
