  1. Try 8638
  2. Try 2131
  3. Try 4582
  4. What model radio please? What does it say on the front panel?
  5. Please READ the Lost Radio Code FAQ (as requested).
  6. Try 5309
  7. Removal 1.Door trim panel - Removing and installing door trim panel 2. Return spring 2 - Unclip from the door handle 5 and the door trim panel 1. 3 Sleeve - Pull off from the return spring. 4 Oval-head screw 4 (4.2 x 13) 5 Door handle 5 - Undo oval-head screws 4 and pull the door handle out the door trim panel 1. Installation is the reverse.
  8. Technically no it is not closed - there is a separate support topic for each DIY. Just click on the button...
  9. Do a search here for "B pillar" - include the quotes.
  10. Did you see the video DIY here
  11. Try 6986
  12. No - that is not allowed here. All Porsche manuals are copyrighted material and no links or copies will be provided here (for obvious legal reasons). This topic is closed and locked.
  13. Unfortunately the author has removed the PDF file. You can try and PM him.
  14. Try 9548
  15. Try 6108
  16. Fault code 1276 -- Hydraulic pump Possible cause of fault: - Plug connection to PSM control module is corroded or damaged (faulty plug connection) - Hydraulic pump (faulty)
  17. Exact model and year of your car please...
  18. Try 9045
  19. Try 9067
  20. Try 4624
  21. Not too difficult with the right tools. Make sure you have the correct compensation plates for your springs. Once installed I would (carefully) drive the car for a week to let the springs settle - then do a full alignment. You will need an alignment due to the ride height change by moving back to factory springs. Plus it's a safe move whenever you do suspension work.
  22. Try 0716
  23. Try 2138
  24. That looks normal to me. There is always (on any engine) a small amount of wear.
