  1. Try 0942
  2. Please read the Lost Radio Code FAQ "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  3. Try 3256
  4. Try 9489
  5. Perhaps a loose or poor connection on the oil pressure sender. This is a known weak area.
  6. Try 1208
  7. Try 9532
  8. Perhaps the Speed gong is set on your car as the spoiler (working or not) does not generate any beeps.
  9. Try 4394
  10. Arena Red Pearl (97-99) / Arena Red Metallic (00 on) Water-based paints (84S) and Conventional paints (84R). US/Canada cars all got water-based paint (per EPA rules).
  11. Try 9082
  12. Try 8764
  13. Try 0623
  14. Obviously you did not read the Lost Radio Code FAQ did you... ;)
  15. Try 5871
  16. Please read the Lost Radio Code FAQ What is the model number of your radio?
  17. Try 9879
  18. What is your front wheel width and offset?
  19. I have not seen the prep TSB for 2015 models - it is not yet showing up in PIWIS TSI. In the past some hardware and programming were both required.
  20. Try 0215
  21. Yes, this option can likely be added via PIWIS 2 - but Porsche requires that the dealer/OPC get the authorization directly from Porsche - after proof of purchase. They do this to prevent dealers/OPCs from giving options away for free.
  22. This is the 2nd radio code you have requested a code for in the last month - perhaps you should consider a donation to this site.
  23. Thank you. Try 1049
  24. This is the 3rd radio code you have requested a code for in the last two months - perhaps you should consider a donation to this site.
