  1. Iten 17 or item 15?
  2. Nope just plastic clips - which may break. (999 507 685 01).
  3. Can you make an arrow pointing to the part?
  4. From the service manual... Fault code 1228 Airbag switch (activate/deactivate passengers' airbag) Possible cause of fault Short circuit to ground (based on the wiring of pin 81 of airbag triggering unit and pin 2 of airbag switch) Open circuit/short circuit to B+ (based on the wiring of pin 81 of airbag triggering unit and pin 2 of airbag switch) Faulty (airbag switch is faulty) Airbag triggering unit incorrectly coded when locked Triggering unit for airbag faulty
  5. Try 8767
  6. Try 6563
  7. Try 4653
  8. This is your fourth request for a radio serial number - please consider a donation to help keep this site running. Try 9632
  9. From the service manual. Press temperature sensor -10- into the inlet grille. So, if this is not working then you may have a damaged sensor or the holder in the bumper maybe damaged.
  10. Try 9323
  11. Try 8197
  12. Try 8989
  13. It just snaps back into place from the back side.
  14. DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  15. Try 2832
  16. Well if they cloned an ECU that had a loss of program memory then your second ECU is likely to also have that same loss. When you re-program the ECU from a PIWIS tester get the whole program re-written to the ECU - plus any bug fixes Porsche has found.
  17. It worked fine when I just tried it. Please try again.
  18. Try 5329
  19. Try 6910
  20. Yes, it is basically re-flashing the program memory of the ECU. Certainly worth a try. Each ECU must be programmed to the car - no straight swaps.
  21. Did anyone try to reprogram the ECU? I would certainly do that before buying a new or used ECU.
  22. Your VIN does not have any radio info. We need your radio serial number. From the Lost Radio Code FAQ ... "How to get your radio serial number? CR-220/CDR-220: Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio. Or, if the radio is out of the car the then the serial number is on the label. CR-210/CDR-210: Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear. Or, if the radio is out of the car the then the serial number is on the label."
  23. Try 8609
