37,340 -
Days Won
536
Posts posted by Loren
Okay, that is for the carpet trim not the tail light.
999 049 005 40 Plastic Nut T5/27x9.8 -- US MSRP $3.49 each
34 minutes ago, CJChaps said:
Hi Lauren.
I previously posted, and it looks like I had a number one off in the serial number. Can we try again please?
Becker CDR 210
Type BE 2232
Serial # U5011528
My apologies, I appreciate what you do.
Clint
Try 9124
- 1
I don't know for sure but I doubt it.
The CDR-23 and newer radios all use the MOST fiber optics to speakers and amps. As well they talk on the car's CAN system to the DME which is where you enter the serial number info.
CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected. -
2 hours ago, CJChaps said:
Hi Loren,
Code 9132 didn't work. It's there another code to try?
I appreciate the help.
From the Lost Radio Code FAQ...
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
46 minutes ago, Sean K said:
Ate these available, I would like to purchase one.
1 hour ago, Jason Giachetti said:
Hello,
Good evening and happy new year. Was hoping anyone could help here. I need the code for my radio
CR 220
BE 4362
serial no w5002465
EC102
Thank you in advance,
Jason
Try 4846
- 1
Just now, Shanghai_todd said:
Loren.. Happy New Year, hope all is well.. appreciate your help for a code on the following :
1999 996
CDR-220
Serial number X5013849
Thanks..
Try 6464
The 02 is for MY2000 and newer and has a seperate listing in PET so there is a difference likely something to do with the new DME that year.
6 minutes ago, Daniel996 said:
Thanks, I'll buy it then. I read earlier about the difference in the Fuel Clock between c2 and c4 and this is where I am most concerned.
It will require recalibration regardless of which cluster is used. The difference on the C4 is the saddle bag fuel tank (due to front wheel drive geometry).
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC." -
3 hours ago, Daniel996 said:
Hi Loren
996 1999r carrera 4 manual trans.
Pt will likely work then.
1 hour ago, PGJ said:
Hi - I would really appreciate some help unlocking the radio in my “new to me” Boxster:
I got the following info following the instructions in the FAQ:
I have a CDR-220
type: 4462
Ser no: 15062082
Thanks so much for the help!
Try 0276
What year is your car?
The exact model and year of your car is always helpful;.
7 hours ago, STS said:
Loren,
Sorry for the redundancy with a second post but I just found this topic thread for requesting help with radio codes after I sent a separate message to you earlier. Below is the information in my original post.
Thank you in advance for any help you can provide.Hello,
I just replaced the battery in my 2001 996 cabriolet and I do not have the stereo code. Would you be able to help please?
CDR-220
Type: 4462
Serial #: Y5053833
Thank you!
Try 2752
- 1
44 minutes ago, CJChaps said:
Hi Loren. So, my radio says "wait". I disconnected the battery. Once for 2 hrs, then again for overnight. I even pulled it out and unplugged it... Any tips? Also, if I swap the radio for aftermarket while the stock one says wait, will it cause issues? E. G. Is the radio locked or does the lock come from the ECM?
Thanks for your help.
Clint
Somebody didn't read the Lost Radio Code FAQ...
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again." -
1 hour ago, El Duderino said:
Hello, need help please.
- 2011 996 base Cabriolet
- Type 4362
- SN 15050333
Thank you so much!
Try 0586
- 1
From what I can see in the photo it appears to be the oiled filter.
3 hours ago, Red 5 said:
Hi,
would really appreciate some help with getting the radio code.
i have a Becker CDR 21
model number BE 2280
serial number V5012467
thank you
Try 4862
12 minutes ago, theblackshadow06 said:
How did u fix u problem ?
A double beep means that there is an alarm fault that can not be reset. You need to read the fault codes for the alarm system to location the problem sensor or control box.
Replacing instrument cluster
in 986 Boxster Convertible Top Issues and Solutions
You will need to check your state's laws.
In California you must go to DMV and sign a document stating the "real" mileage and the new mileage on the new/used odometer. Also, stating that you will give this information to any buyer.
