  1. Sorry, I have no idea. Please read the Lost Radio Code FAQ "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  2. History has shown the Tip to be sensitive to worn-out or dirty ATF. It can cause all kinds of erratic operation. Make sure the fill is done properly also with the fill level checked at the proper ATF temperature. That would be the place I would start. Everything else will require special diagnostic tools and more cost.
  3. Has the ATF been changed recently? Was Porsche spec ATF used? Most Tip issues are weak or failed solenoids.
  4. It does not look like Porsche sells this as a separate part so your best bet would be a auto salvage yard.
  5. It is always helpful if you tell us the exact model and year of your car. And what the problem is.
  6. These are not a Porsche part so without documentation I doubt we can help you. Try going back to the vendor.
  7. Since I can not see what it is clamping (or supposed to be clamping) - here is where the part number you specified goes.
  8. Covers all Carrera (996), GT3, TT / GT2 and Boxster (986) cars Here is the long explanation from the service manual on the flashing coolant light. "Four functions of the coolant warning light: 1. Engine coolant level too low -- light flashes slowly (0.5 Hz) 2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty) 3. Engine coolant temperature too high -- light is lit; pointer on the right 4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously."
  9. Copyrighted material: By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this site. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted. Several years ago Porsche's lawyers sent me a "take-down notice" to remove all copyrighted Porsche material from the website or face litigation. I had no choice but to comply with their demands.
  10. From the Lost Radio Code FAQ... "I get a WAIT on the display - what do I do? You have to wait at least 30 minutes before trying again." Try this code 5468
