CJ_Boxster
Everything posted by CJ_Boxster
  1. i replaced some bearings in the pulleys on my engine from a shop that specialise in just bearings if i had all the measurements or the bearing the self i should be able to get them i to have a knocking noise from the suspension i will look at mine and see if i can get the bearing. i also have a random knock which i thought were the wire ties that hold down the roof. my noise comes from the left rear 98 boxster UK Please do! It would mean alot to us all!!!! Usually the rear control arm rattle is worse on hotter days, and makes lost of noise at low speeds over cracks and bumps in the road... hopefully thats what your expierencing and the Shop you take your car to will locate the bearing for the application!!!!!! it's not a normal looking bearing; here's a pic of the cartridge: So is the rattling due to that white nylon jacket wearing thin around the ball?
  2. Why did this happen. Currently i have a CEL MAF code and had gotten a P1115 but that hasnt come back in a week after I cleared the code. I do have an oil leak on the rear passenger side of the engine. Since yesterday or the day before, my throttle response has been alittle slow and my acceleration has been alittle weaker than im used to in these past 3 days... Any ideas? or anyone experience this same issue and solved it?
  3. i replaced some bearings in the pulleys on my engine from a shop that specialise in just bearings if i had all the measurements or the bearing the self i should be able to get them i to have a knocking noise from the suspension i will look at mine and see if i can get the bearing. i also have a random knock which i thought were the wire ties that hold down the roof. my noise comes from the left rear 98 boxster UK Please do! It would mean alot to us all!!!! Usually the rear control arm rattle is worse on hotter days, and makes lost of noise at low speeds over cracks and bumps in the road... hopefully thats what your expierencing and the Shop you take your car to will locate the bearing for the application!!!!!!
  4. I just called TRW and they say they dont have any aftermarket listings for Porsche boxster, No bearing cartridge at all.
  5. insite above said he found a manufactor of the bearing cartridge but i asked that mofo to give us the part number and the company who supplies it but he hasnt replied in nearly a month. never found a source for the part. it's a TRW bearing, but no part numbers on it. i did some experimentation with modifying / repairing the cartridge with mixed results. it will be a lengthy post; i'll get it up this week (lots of pics). cant wait!, The idea of removing the cartridge from the arm and filling it with urethane and a sleeve ran through my head but, urethane would likely not be able to handle the shock and twisting that the rear control arm does.
  6. I hope that is the case, I remember reading other members threads on how after they replaced the 1 sensor, they received CEL's for the other sensors... Ill first check them with my Ohm meter on the weekend or sooner, depends on how upset i get with the cel and performance drop.
  7. Thanks Loren, Lets say i had to replace the sensor cause the reading were not right, would that mean i would have to replace all the sensors to avoid the CEL appearing and saying the others are bad cause theres a fresh new one installed?
  8. I know the P1115 code is "Oxygen Sensor Heating 1 After Catalytic Converter - Above Upper Limit" But whats that mean, does that mean my O2 is going bad or does that mean my a/f is too lean cause of some other issue like a possible bad MAF or vacum leak? Anyone else experience these 2 codes at the same time? About 5 minutes before the CEl turned on, i was in 3rd gear 2700rpm and i slammed my foot on the gas to see how responsive the car is and once it reached about 5300rpm's it felt like i had let go of the gas pedel, then pressed it again... kinda scary, then 5 minutes later the CEL came on. And ever since then, the car has run alittle rough... misfires alittle during idle, acceleration isnt very responsive.
  9. insite above said he found a manufactor of the bearing cartridge but i asked that mofo to give us the part number and the company who supplies it but he hasnt replied in nearly a month.
  10. I see what you mean, For instance, you would like to have your headlight low beams in the on posistion and as soon as the key leaves the ignition or is placed in the Off position, the lights also turn off, Its a nifty hack is someone were to make it for our boxsters. You probably can look for a wiring diagram for the ignition and see if there is a spare accessory pin that you can use that cuts power when ignition is off, then you can run the Headlight main power wire on the headlight switch to the ignition, then back to the headlight switch so if the ignition is off, that will cut the power to the switch. It can be done and i wish i had it. You try it first and let me know how it works for you.
  11. So are you telling me that the AC controls will only fit in the lowest slot... if so, is there anyway they will fit in the slot that the thread starter is attempting to fit his AC control in?
  12. I dont remember at all, it wasnt the finest stuff pepboys sells but i think the packaging said that for sanding primer... i sand the base coat anyway.... I would buy the variety pack if i were to do it again. The Steps are "removal, prep(wipe down), sand, Wipe Down, primer, primer, sand, primer, paint, Sand, paint, paint, clear coat, clear coat, clear coat and reinstallation" I would advise anybody wanting to paint their console to let it dry at least 24 hours before any sanding. The paint will not have even fully cured after 24 hours but it is good enough to sand. If you sand too quickly after painting the whole job will be ruined. With metallic colors you can sand the metal flake right off if you are not careful because it tends to float to the surface. I did not sand the base coat of my console at all. I used very light coats up until the last coat of color which I left glossy and let dry overnight before clearing. I used 400 grit wet paper to remove the factory finish down to the plastic, 800 grit to smooth the plastic, 800 grit after the high-build primer, and 1500 grit to sand the clear before buffing. The reason i sand the primer once and the base once was to only sand off excess and allow little deposits to settle in the pits that the plastic originally has. I pretty sure its ok to sand a single coat of primer or paint after about 15-20 minutes on a low humidity day The pits are a big problem. The stock finish settles in there and part of the problem with the original finish is that it isn't well bonded to the plastic, so it flakes off due to age, UV, sweat, sunscreen, whatever. I would never want to paint over that stuff primarily for that reason. Sand, sand, sand until all those pits are gone, then sand with the 800. You MAY be able to get away with sanding after a half hour, but I would not risk it. Let the paint cure 24 hours (longer if you can wait) and the end result will be much more consistent. Well i shouldnt have anything to worry about since 1) it wasnt flaking when i painted it. and 2) its painted over and therefor protected from the elements and shouldnt age anymore from the original surface area anymore.
  13. Well, i filled my tank to the brim and i drove about 120-135 miles before using half a tank of gas, So i would be getting anywhere from 240-270 miles per tank full...... topup the entire period. whats that equate to in mileage per gallon?
  14. I dont remember at all, it wasnt the finest stuff pepboys sells but i think the packaging said that for sanding primer... i sand the base coat anyway.... I would buy the variety pack if i were to do it again. The Steps are "removal, prep(wipe down), sand, Wipe Down, primer, primer, sand, primer, paint, Sand, paint, paint, clear coat, clear coat, clear coat and reinstallation" I would advise anybody wanting to paint their console to let it dry at least 24 hours before any sanding. The paint will not have even fully cured after 24 hours but it is good enough to sand. If you sand too quickly after painting the whole job will be ruined. With metallic colors you can sand the metal flake right off if you are not careful because it tends to float to the surface. I did not sand the base coat of my console at all. I used very light coats up until the last coat of color which I left glossy and let dry overnight before clearing. I used 400 grit wet paper to remove the factory finish down to the plastic, 800 grit to smooth the plastic, 800 grit after the high-build primer, and 1500 grit to sand the clear before buffing. The reason i sand the primer once and the base once was to only sand off excess and allow little deposits to settle in the pits that the plastic originally has. I pretty sure its ok to sand a single coat of primer or paint after about 15-20 minutes on a low humidity day
  15. I thinking of getting some kind of elastic bands and mounting them from the interior edges of the plastic window folding points (both sides) to something near the rollbar to pull area i want to fold in towards the rear seats. Only issue i see with this is the elastic losing its elastisity.
  16. I dont remember at all, it wasnt the finest stuff pepboys sells but i think the packaging said that for sanding primer... i sand the base coat anyway.... I would buy the variety pack if i were to do it again. The Steps are "removal, prep(wipe down), sand, Wipe Down, primer, primer, sand, primer, paint, Sand, paint, paint, clear coat, clear coat, clear coat and reinstallation"
  17. Save that center console. on a free weekend, you can go buy a can of pretty spray paint, fine sand paper and clear coat spray paint and have yourself a really nice center console. Picture below took me only the last half of one weekday to complete, removal, prep, sand, paint, paint, sand, paint, paint, paint, clear coat, clear coat, clear coat and reinstallation.
  18. and if its a head gasket, they isnt anyother way of telling unless you remove the head and see the breach in the gasket. Whatever you do, DONT put radiator stop-leak to cure the leak, not sure if porsches like stopleak leaking into the block and clogging oil gallys.
  19. The problem with the idea of it being the oil separator is that the only function of the oil separator is to keep oil from intake, has nothing todo with water... Just oil and vaccum, no water goes in, or out.
  20. you can probably tap into the rear parking light power and have that as a power source for the license plate light power.... its close by and would run off the headlight switch just like the parking lights and as if you still had the daytime running relay installed still.
  21. Yes screws under the rubber mate. under the ash tray, under the shift boot and also one more screw... pull up on the coin holder and once removed, you will see a screw under that.
  22. Well as an Ex-mechanic and with a father with a lifetime of Mechanic experience... I can tell you that means your head gasket is bad. not good at all, also another possible reason for water in the oil is a cracked head... maybe even a cracked block depending on location of the water passeges on teh block and heads.
  23. Could you give us the part number and link to the bearing cartridge so that the info stays on the forum for good?
  24. YES THATS WHAT IT SOUNDS LIKE!!!! well i get the Secondary Air injection error code for both cyclindars 1-3 and 4-6 so would this noise mean that the root of all my 2 air injection CE codes is the air pump?
  25. Hey people, im getting a vibration noise on cold starts in the AM, When i start the MY97 boxster, i hear what sounds like a fan turn on in or around the engine bay. Its sorta vibraty...if thats a word...which its not. It goes away after about 4 minutes, sometimes less. If it goes away in 4 minutes and if im sitting for the 5th minute in traffic, it'll come back for 1 more minute. Once the engine it warmed up abit more, it doesnt come back.... Whats that noise?
