RFM
Everything posted by RFM
  1. Pink and green coolant can be mixed without problems.
  2. I would suggest a visit to the dealer, to check it out with the PIWIS tester, since the car is still in warranty.
  3. The best you can do is change both bulbs, they have approx. the same life time. As you mentioned, there is nothing wrong with the steering sensor or fuse. They use a system if the left corn.light is out, the right does the same, if the right is out, the left still working, so they are not wired in series but controlled by electronics.
  4. The intermediate shaft build in the Turbo and GT2/3 is a lot smaller and shorter, more important is the much better bearing instead of the M96 half floated large shaft which Loren indicates.
  5. The child seat bar should be logged out by a PIWIS tester.
  6. It make it easier if you loose/remove the radiator bracket from the car body, after you have disconnect the aircond. condenser from the radiator with the lines still connected. You can remove/reinstall the 3 clips much easier and there is no chance to break off the radiator connectors.
  7. The valves in the DFI Cayenne engines stays clean and carbon free in any case, as far as i have seen in a test car with 100.000 Km on the tacho. Since there is no fuel injected on the intake valve stems, only filtered air, there is no deposit or whatever on the stems. There was no abnormal deposit in the combustion room neither.
  8. Read the fault codes first, could be the lock/control box more than the micro switches.
  9. Reading too much is too confusing, fill the engine up with approved oil to the specified level and check for noise. If the noise is still there, let check the engine in a dealership or independent.
  10. Since you ordered a new AOS, i would replace him anyway, and recheck for smoke after a day or two. At the same time, clean the throttle body and intake manifold as good as possible from oil residues.
  11. Let check (replace) the mirror adjustment control switch as well, since a switch manipulation solves (temporarily) your problem.
  12. The sensor is located between cylinder 5 and 6 ( passenger side LHD car) on top of the cylinder head. Remove the shield in front of the spark plugs, bend an open 19 mm key to 90° to remove and install the sensor.
  13. You got it right, a new window regulator is needed to help you out.
  14. Time to hook up the car on a PIWIS tester, without fault codes, it's still a guess.
  15. Iporsche The P0021 fault is not the cause of a non started engine, must be something else.
  16. I don't know what it is, but the wiring looks messy and is not exactly a original factory install.
  17. It should be much easier if you know what kind of oil it was, transmission, engine or ATF, and where exactly the leak is. A leaking ATF oil pan seal is always possible.
  18. Sequential racing gearboxes are, and works, complete different than PDK. The only equation is sequential shifting, but the Tiptronic do the same and is, again another different system. The currently used PDK is even not able to manage the high torque of the Turbo.
  19. Looks like the micro switch in the trunk lock is faulty, this is common. The switch is available separately. Do a search on the board here for DIY.
  20. Correct Richard, it happen once in a while, Tiptronics are specific in trouble shouting concerning cooling issues. It is by the way the cheapest and quickest way to go, to check this out first, no parts needed, just a lift and 10 minutes of your time.
  21. Sounds like Tiptronic cool water/oil exchanger problem. The water valve is vacuum controlled, in normal temps. and driving conditions the exchanger is shut off (vacuum on the valve). In case of 1) leaking vacuum tube 2) defective valve membrane 3) defective solenoid or electric wiring, the exchanger (receives no longer vacuum) is now always active in the engine cooling system, the engine will run 20°C cooler. If the engine runs too cold as programmed, after a long drive, the red lamp comes in as "implausible signal". Let this check first, before changing the thermostat, temp. sensor, etc.
  22. I have heard in May 08 that all regular M96 engines are replaced by MA engines, but it was still in 08, times are different now. I check it out when i visit the after sales dept. next spring.
  23. bogein lives in Norway juniinc, perhaps he have to take some ferry's at it's way to the dealership.
  24. Only technically spoken, the alternator will charge the battery at idle. Unfortunately this procedure is not good for the engine health, better is to take the car out for a 10 miles drive once a week, if you can't use a battery tender.
  25. The Tiptronic memory is readable with the Porsche PIWIS tester and probably with DURAMETRIC diagnostic tool, the CEL is engine and environment related and have nothing to do with the gear box. You can buy a DURAMETRIC tool, visit the web side for instructions and possibilities.
