JFP in PA
  1. OK, you are dealing with the dreaded IMS. If the shop is a dealer, I have to assume they know the correct procedures to do this. Yes, there is an LN bearing that will fit, and it is a much better unit than the OEM.
  2. Is this what you are refering to? And if so, how did you get from the water pump on the front of the engine to the rear without the flywheel? If this is it, it is the IMS bearing assembly, which can be replaced without having to rebuild the engine, unless the engine has "jumped time" and bent all the valves................. Also, is the shop doing the work a Porsche shop? Reason for asking is that before you remove that triangular cover, the engine needs to be locked at TDC and the cams locked in position using special tooling to prevent the engine jumping time. The engine may be just fine, but pulling apart the IMS is not something that should be tackled by a shop without considerable experience as well a the correct tools.
  3. It does, but I'd still like you to answer my questions from above............... something ain't right here...........
  4. I'm a little confused here, what "wire around the bearing" ("When they got to the leaky gasket, they were face to face with the bearing. The cover had already broken off and was missing, and they showed me the amount of play and rattle in the bearing, and how the wire around the bearing was all bent")are you refering to???
  5. 1. No, not necessarily. 2. Yes, uncover the tank, make sure it is full the mid level and put a pressure tester on it. 3. Depends, could be green (early) or pink/amber (later). They are both compatible.
  6. If you are really interested in the belt tension, there is a $200 tool that measures it by the amount of belt deflection...............
  7. Just wondered how you changed your condenser or got access ,as I have to change the left condenser on my 987 boxster. I think I have to remove the front bumber cover and the air intake. Any thoughts if you have done this. peter The front bumper cover has to come off..................
  8. You are kidding, right? At least I hope you are kidding.......................
  9. You need a new tank; when you order it, also get the latest cap (ends in either -03 or -04) as well..................
  10. Most likely either a bad cap or a cracked coolant tank....................
  11. Or you can get a complete kit from Yellow Dog Motorsports and have in installed in 5 min................
  12. Most likely, it is one of the axel assemblies. For some reason, a lot of shops do not properly clean, Loctite, and torque the axel flange bolts; and they back out, killing the drive. Usually, fresh bolts, Loctite and re-torque is all that is needed, as long the flailing axel didn’t hit anything important…………
  13. Yes, we use Stant pressure testers in the shop just about every day. You will need to obtain the correct adaptor for a Porsche, but the Stant system will work with anything........ Thanks JFP. I was just looking at the Craftsman tester. It has 8 adapters. Does the car have to be running? Because the coolant leaks on one of the pulleys and ends up all over the place, making it hard to spot the leak. Thank you. Mike No, the car does not have to be running. You can also add a UV dye that will show where the leaks are as well. As for the Craftsman unit, we use Stant becuase the make adaptors for anything which you can add as you need them; sets that come with a cluster of "most popular" adaptors usually don't make sense because you end up with a bunch of stuff you never use..............
  14. Yes, we use Stant pressure testers in the shop just about every day. You will need to obtain the correct adaptor for a Porsche, but the Stant system will work with anything........
  15. I would be concerned about that amount of debris in the filter, especially as the bits are ferrous. First step would be to pull the sump and have a look. While the block and heads are alloy, there are several possible sources (rods, cams, crank, oil pump, and the IMS) for ferrous metal.
  16. I have to agree with Wayne on this one, metal in the oil filter is never a sign of anything good………. Have you tried to determine if the metal is ferrous or not? If there is a good metallurgy lab or university near by, they can test the bits and tell you what type of metal it is, which would be worth knowing.
  17. First of all, it had better not be a "trickle charger"; they never shut off and slowly cook your battery. What you need is a "maintainer", which only applies current when the battery needs it, then shuts down. That will keep your battery in optimum condition without cooking it. Secondly, these cars are set up from the factory to have the maintainer plug into the cigarette lighter (it is hot all the time for this reason), so get one with an adaptor to do that............ Yes it's a maintainer but no cigarette lighter adapter So back to my original question, hook it up directly to the battery since I don't have a lighter adapter? Would be the quickest way..............
  18. 1. What are the main coolant loss problem area's Coolant tank, hoses/clamps, water pump, radiators, head gaskets, cylinder heads. 2. If parked for long time can the coolant evaporate Absolutely not........... 3. What would you guys check. System pressure test; if loosing pressure, add UV dye and try to spot leak(s). If no external leaks, look for intermix, run cylinder leak down.
  19. First of all, it had better not be a "trickle charger"; they never shut off and slowly cook your battery. What you need is a "maintainer", which only applies current when the battery needs it, then shuts down. That will keep your battery in optimum condition without cooking it. Secondly, these cars are set up from the factory to have the maintainer plug into the cigarette lighter (it is hot all the time for this reason), so get one with an adaptor to do that............
  20. There's absolutely nothing you can say to make me feel stupider I actually saw a similar bolt about that size and in a similar location, referenced in something else I happened to read recently. I had my 8mm hex handy, I just got confused on a different procedure and as I said, as soon as I got horizontal I made a dumb decision -- which probably isn't the first time, nudge nudge wink wink Hey, if it makes you feel any better, you are not the first one I have seen do this. One person read somewhere that "dirty oil gets trapped in these 'blind holes' and cause IMS problems" and commenced to pull out all the tensioners and even the oil pump pressure regulator to "get rid of the bad oil". His real problems began when the put everything back and tried to start the car; his wallet suddenly got a whole lot easier to sit on just after that.... You live and you learn...............
  21. When I said "on the ground", I meant while the car is on jackstands. Everyone seems to make a big fuss over bleeding the clutch, it really is not that hard with a short metric box wrench................
  22. That's what I'm doing. Not going to risk a 50% chance of a $4k rebuild on a $500 bet (towing + service). Thought my odds would be much better, so I'm very glad you responded. Thanks again. We have seen them run, albeit poorly, one tooth off; but it matters which tooth and in which direction it is off. Cam allocation in the M96 is not for the faint of heart. In the future, might I suggest not loosening anything until you know what it is? Just a thought...........
  23. What you are not accounting for is that the cams move relative to the crank and each other once the engine starts and gets oil pressure, and then again as it starts to increase in RPM (hence VarioCam). So you could rotate it by hand, feel nothing, start it and still have a boat anchor. A static rotation test can still give you a false sense of security. That said, if you really want to try to rotate it, before I'd do the tire bit, remove the front engine cover, and use a socket to rotate the front pulley/dampener BEING SURE TO ONLY TURN THE ENGINE CLOCKWISE AS YOU LOOK AT IT FROM THE FRONT (rotation the other way, even the slightest amount, will lead to disaster)! This way, you have less leverage and would feel any contact sooner. But again, you may feel nothing but still have a potential issue. I'd suggest leaving it alone, flatbed it to the shop and let them properly check it.
  24. Look underneath a 911 variant with the same engine and check out what is in the way (the exhaust system is up alongside the engine due to space issues), your Boxster is a relative "cake walk" in comparison........ On some 911 models, you need to remove some of the exhaust just to get at the spark plugs..........
