JFP in PA
  1. I don't see why it wouldn't work, but overspeed pulley adds a complication and potential future failure point that the fixed pulley does not have.
  2. Back in the day, I remember them being optional parts. There are currently multiple used sets on eBay, and there were some aftermarket suppliers as well, such as an outfit called Dido Tuning :
  3. They may no longer be available due to the part's age, which is not uncommon. You might check with a dealer to see if any still are on the shelf somewhere in the system.
  4. A scan of the car with a Porsche specific tool (Durametric, PIWIS) can identify if the M535 anti-theft/immobilizer system (Central Locking Unit or CLU) is present and functioning. Diagnostic tools like Durametric or Porsche System Testers can query the alarm module for error codes, confirming its status. This system is also located under the driver's seat.
  5. Check your fuel trims, bet at least one bank is running lean.
  6. We have seen quite a few complaints of engine speed related noises being tracked down to bearings going bad in tensioner rollers, water pumps, alternators, etc. I would start by removing the belt and trying to rotate the various components by hand, which often identifies the problem unit without even starting the engine. Everything should turn smooth and quietly; anything that doesn't should be suspect.
  7. Welcome to RennTech I would start by looking at the front engine mount beneath the water pump. I would also consider temporarily removing the serpentine belt and then start the engine to see if it goes away as it could be one of the belt driven components or the idler assembly.
  8. At the end of the day, it is your car and your money. Just be aware that there always has been a limit as to how cold an automotive AC can be allowed to get; some manufacturers actually set a minimum permissible temperature for their system in order to prevent some rather strange problems. We actually had a customer that complained his system seemed to be cooling fine and then would just shut off for no apparent reason during a rather warm and humid period. After some intense diagnostics, we discovered that his system was getting so cold (very low 30F air temps), that under some humidity conditions, the car was actually freezing over the inside heat exchanger, blocking air low until it defrosted, giving the appearance that the AC had quit. We traced the problem to an AC compressor replacement prior to his purchase of the vehicle, where the wrong part number compressor was installed that had a higher capacity rating than the factory unit. We evacuated the system, replace the compressor with the correct part number, recharged the system and found the air temps inside the car's ductwork now stayed at around 41F, one degree above the manufacture's minimum allowable internal air temp. The car never froze up again. While getting you system's AC temps as low as possible seems like a worth goal, sometimes the law of unintended consequences rears its ugly head............
  9. I do not have a useful recommendation but would suggest contacting your local chapter of the Porsche Club of America as they typically have background on known Tiptronic repair facilities in your geographic location.
  10. Welcome to RennTech Tiptronic problems are never fun, and often complex and difficult to diagnose and repair, which is why many shops shy away from working on Tips. Potential issues causing P0740: -ATF supply (as you have fresh fluid and assuming it has been topped up correctly, this would only apply if the filter were the problem and not moving sufficient fluid) -The torque converter itself is bad. To properly diagnose this, you would need some very specialized and very expensive tooling. -Pressure regulator 4 is problematic -The electrical triggering connection to pressure regulator 4 is bad (shorted, disconnected) -Hydraulic control unit (read valve body has sticking valves)
  11. I always remain circumspect of "magic bullet" additives, especially those touted on the internet, and particularly when used in very expensive and sensitive systems like air conditioning. The ac systems in these cars have proven to be both effective and long lived as designed, I don't really see any advantageous reason to do this as a well maintained and functioning system doesn't need any help.
  12. No problem, some posts don't get answered for a simple reason: Neither form members nor staff are familiar with the particular subject, like swapping electrical or electronic components from different year or models. While we have seen a lot of unusual things over the years, like trying to transplant a 996 Mezger turbo engine into an early Boxster, I would be the first to say we haven't seen absolutely everything, and for the sake of fidelity and technical accuracy, sometimes we simply do not have a functional answer. 😉
  13. Just because no one has responded to your specific question, that does not mean that there is anything amiss with the forum. You may be the first to attempt this kind of swap, so YOU may be the best person to post the answer. 😉
  14. If the oil cap is hard to remove, you have a high vacuum level in the sump, which is bad for a variety of reasons, including lean stalling. The correct way to access the AOS is to fully warm up the engine by driving the car for 10-15 min, then replace the oil cap with the one in the picture above with a hose that connects to the digital manometer. If the vacuum level exceeds 6-7 inches of water vacuum, the AOS is leaking air into the intake system, causing the lean stall conditions. The normal level of vacuum is typically 4-5 inches of water, which is a really weak vacuum level, so it doesn't take much of a leak to cause problems, which is why we always checked every car that passed thru the shop with the manometer.
  15. The AOS can either be pin pointed or eliminated by having the car's sump vacuum level checked with a digital manometer (most quality shops have them as the AOS is a perpetual issue; surprise the dealer didn't do this).
  16. Could be the harness, or just low voltage on the harness.
  17. Sorry to hear, you made the effort but sometimes the damage is just too extensive because salt water immersion is death to so many electrical and electronic components. Good luck with your new ride………
  18. The valve, however, is located on the engine under the passenger side intake plenum. at a minimum you'll have to remove the two crossover tubes to access it. worst case you have to pull the whole passenger side assembly off.
  19. Difficult to analyze remotely; could be something sticking like the ignition switch or starter relay; but either would require more diagnostics................
  20. Not really. Get the bushing installed, if it still sticks, try spraying the plunger with DuPont's dry film Teflon spray (leaves a dry film of lubricant that does not attract dirt):
  21. If the solenoid were bad, it would throw its own code. Yes, it is dirty, but probably not related to you problems...................
