JFP in PA
  1. I would suggest contacting the compressor manufacturer and ask their advice as most of the PAG oil function is in protecting the compressor components. You can also purchase an AC flushing kit, which uses a solvent run thru the system to remove oil and any metallic debris from the system, and leave the entire system clean as it was new.
  2. P0421 is the code for a possible catalytic converter issue. Get the car scanned with a Porsche specific scan tool and check the O2 sensors for correct function.
  3. The code is for an open circuit, which are usually harness related.
  4. Battery reserve capacity are directly correlated to their size and weight (bigger and heavier, more metallic lead and lead oxide, which equals more capacity). Long before I would be looking at an Optima, I would be considering the Odessey AGM battery line. And yes, I was an Optima fan for many years, but after several ownership changes, we started to see brand new Optimas that were 7-8 pounds lighter than the same model they replaced, which is not a good sign.
  5. Only valid resources would be the diagnostics listed on a PIWIS system as none of this information was ever in print. Using the list I provided, you should be able to assume some basics like wiring continuity, wiring shorts to ground, voltage readings, does the cam angle change when activated via Durametric or PIWIS, etc. You need to remember that even the OBD II diagnostics manuals for the earlier cars only provided a sense of direction, not a set of directions. You need to get out your digital multimeter and start poking around............
  6. Probable Causes: Control Line Circuit Open Control Line Short Circuit to B+ Control Line Short Circuit to Ground Fuse Faulty Solenoid Hydraulic Valve Faulty Voltage Supply Circuit Open Diagnostics time..............
  7. I believe you are actually referring to a P0010, which is typically the code for an "open circuit" on that bank 1 sensor.
  8. Before you recharged the system, did you fully evacuate it to remove any moisture? If you didn't, you need to recover the current gas charge, evacuate it, and then recharge it along with any required PAG oil.
  9. There are very few rebuild shops for the M96/97 engines, even fewer good ones, due to the lack of credible published internal specs and the incredible number of specialized tooling required and a total lack of oversized bearings for cut cranks. Normally, when the internal and external journal and shell bore diameters are good, the only way that the crank locks up upon assembly is either the crank or the carrier do not align true (one of the other is bent).
  10. Something does not make sense here; if the difference between the crank journals micrometer readings and the bearing "cage" internal diameters with the shells installed and torqued to spec is 0.002, there is no way the crank should lock up unless the crank carrier is warped by the new bolts or one of more bearing shells are installed incorrectly. If it does need to be line honed, you should try LN Engineering in Momence, Illinois; they are one of the leading machine shops for these engines.
  11. I think you may have an alignment issue.
  12. I would say you have a electrical connection issue with the switch.
  13. Welcome to RennTech Couple of thoughts: You cannot just switch air bag control modules without coding them to the car, these modules are used in multiple models, so it has to know what it is dealing with. You really need to get the car scanned with a Porsche specific tool like the PIWIS system, which is also what you need to code modules to the car, and can give you vastly more detail than your global OBD II scanner can, such shorts, open circuits, etc. You also need to be aware that many times air bag codes in these cars are related to seat belt buckle issues (poor contact for electrical circuits).
  14. Click on PayPal, they should show you that option.
  15. Heater is directly behind the throttle body (1/2inch) on top of the intake.
  16. Please be aware and make note of the fact that such materials are the protected intellectual property of Porsche, who vehemently protects such materials via law suits and website seizure's, and as such any reproduction of these protected materials will not be tolerated on this forum, as will any attempt to publish direct links to them, which is strictly against forum rules you agreed to when you joined.
  17. Now you know why Loctite exists...........
  18. For a 2002 Porsche Boxster S, the fuel pressure at the rail should be around 3.3 to 3.8 bar (47.9 to 55.1 PSI), and the fuel delivery rate should be around 850 cubic centimeters (cc) in 30 seconds. The test port is on the passenger side fuel rail, under cap #7 you will find a Schrader valve :
  19. Have you tested the car for fuel pressure and delivery using the test port on the fuel rail? If it has full pressure and delivery rates, the answer would be "no". And, as noted from your first post, you got an "immobilizer not ready" warning..............
  20. If the immobilizer is dead, the car will aimlessly turn over and never start; it is your anti theft system. The most common reason these things fail is moisture, but we have seen them with burnt circuit boards as well. Take the box out, open it and look, only then you will know if it can be excluded. And yes, it would be expensive as the part is pricey to begin with and you need access to a PIWIS system to code it to the car.
  21. 8035 Diagnosis information rear - Reversing light Possible fault causes - Open circuit/contact resistance in wiring, sockets, plugs and terminals - Short circuit to ground in wiring - Reverse gear switch faulty - Tiptronic control unit faulty - Short circuit to ground in point SP039_SPRFL_2 (driver's seat) of the ParkAssist control unit
  22. Reread what Loren posted above: 8035 Diagnosis information rear - Reversing light Possible fault causes - Open circuit/contact resistance in wiring, sockets, plugs and terminals - Short circuit to ground in wiring - Reverse gear switch faulty - Tiptronic control unit faulty - Short circuit to ground in point SP039_SPRFL_2 (driver's seat) of the ParkAssist control unit And please do not double post your problem, it is against forum rules................
