juniinc
Everything posted by juniinc
  1. full syntheic will expand quiet a bit when they are hot. should check the dip stick when it's warm,,,
  2. I don't believe there is any illumination wire for a HU.
  3. I like those Kappa series, personally have a set in the back. & a set of Rockford P142C on the dash,,,my RF 4" depth was close to 1.6" . with those mounting rings Kappa 42.9 should be fine. About the door speakers, the signal is passed. unless U'd modify the factory amp, putting coax(full range) speakers wouldn't do any good. http://www.renntech.org/forums/index.php?/topic/21184-audio-upgrade/page__p__113520__hl__fosgate__fromsearch__1entry113520
  4. I'm liking this a lot,,, diggin that carbon fiber.
  5. Nice work,,,Aqus. I dunno if U've seen my sound topic or not? I almost was gonna do what U did, but ended up with a fiberglass between the seats.
  6. with some black rims, would look cool.
  7. At 17,,,1984 944
  8. 1.IMO it should be OK 2.have the code read ASAP
  9. Stay away from that Dex-cool stuff!
  10. It is a personal thing,,, Everyone should stick to what's recommended by the manufacture. G11 & G12 with OAT are compatible with VW/Audi part #. Since porsche has changed the color on their OEM antifreeze, Toolplant took a pic of both(VW/Porsche) lables to compare each other. I tried to find it , but couldn't IMO they are the same thing,,,,,Some belive G12 is the same as GM dexcool,,, I've seen this Dex-cool(OAT) ruining thousands of engines + causing some major repair bills(class action suit). Why? Probably just because of the fact that when the balance is upset ,OAT can come apart get neglected. It is hard to tell U, what antifreeze U should be using. Audi's been using the newest version of their AF G-12+(HOAT)yellowish,,, perhaps it's the reason they upgraded to HOAT. I personally use Valvoline/ Zerex G-05 for my 986S. Coolant, Chemistry, and Corrosion. http://sancarlosradi...eze_coolant.htm
  11. +1 - be very careful about slowly running the engine up to operating temp . Porsche had to relocate/change the engine block manufacturing plant back in late 90's(could be the biggest reason)?. Any cylinder head will crack if its overheated. I know most of us are using G11-G12 with OAT anti-freeze. But if the sysytem gets neglected, cavitation problem can occur which often causes overheating. MB has been using G04 anti-freeze for their cars.
  12. I believe, Doug was reffering to the shift lever console,,,, Nope I believe they do not come on.
  13. Royal Purple 5W-40 every 6000 miles.
  14. 5W-40 Royal Purple.
  15. some fake 18's are out there. Possibly OEM 997 18x8 57mm 18x10 58mm,,, in that case, 4 spacers all the way around would be needed.
  16. Valvoline actually developed the G-12 with BASF. zerex G-30(AKA VW G12) is only sold under private label, and not over-the-counter. "Zerex ExtremeLife" is pretty much the same thing in my opinion. http://www.deckmanoil.com/products.jsp?sub=%2FZerex%2F
  17. This should help. http://www.renntech.org/forums/index.php?s...0247&hl=hid
  18. DIY always,,,I would check for plugs & cracked coil packs first.
  19. starter solinoid is prolly making a clicking noise. sounds like a drained battery,,,
  20. usually happens when U un-plug the seat wiring hardness.
  21. most likely its the HU. get a any kind of after market HU, wire it temporarily to see what happens.
  22. clear side marker w/ clear bulb,,,
