judgejon
Everything posted by judgejon
  1. CA vehicle code section 24602b....two rear fog lights are ok, but it there's only one then its gotta be on the left side, controlled by an amber switch visible to the driver. Seems Porsche does it right on this one..... and the fog light can only be used in limited visibility situations, not tied into the brake lights.
  2. The on-line article by Jim Schrager is very good too. jl
  3. PM sent....
  4. got the Durametics installed, and cleared the air bag light. hope it lasts.... I haven't checked the fault codes yet, 3 for supply voltage, and 46 for belt buckle driver. I still think it all has to do with taking out and putting in a cd with the key out and seatbelt not buckled. ps: we've had 4 German cars and love them, but this situation does seem a bit too much. any ideas re the fault codes? Big thank you to Duram, and continuing thank you to Loren... jl
  5. this is an open thank you to Duram of Durametrics for his knowledgeable help and patient assistance in helping me load the Durametrics software today. thanks, help most appreciated....jl
  6. Bummer, but glad its working out for cheaper than you thought.
  7. on past P-cars with rear fog light there's only been one light attached. I've ssen them hanging off the left side of the rear bumper. my C4S has one light in the left cluster....so I'm thinking its a Porsche traditional approach. Cheers, ...
  8. deal from Sunset sounds good.... Sonnen Porsche in Marin wanted $400 for the valet key...
  9. thank you to Jeff Clark at Sunset....I think we found one.
  10. sounds like a cable issue to me too. I think there are 2 helper springs on the clutch, might check there as well. good luck...
  11. right, the reader I used was at an open gas station, but it was worth a try. I was going to get a generic reader at Napa, but decided not to. I'll check with my local mechanic next week as he has all the right stuff, and probably buy the Durametric software cause it sure seems real helpful. thanks much to all....
  12. Hello again. sure hope so. (and continuing to fight on for old sc....)
  13. Rod: The rubber door seal at the base at the bottom of each window (when the window is up) does not make a completely waterproof seal, and some water migrates into the door cavity. The water that does get in there normally drains out onto the sides of the door sills. When you remove the door panels, be sure to have the battery disconnected and the key out of the ignition so as to avoid getting an airbag light. Regards, Maurice. If you did get the airbag light, how would you clear it? trip to dealerville or mechanicland? thanks much....
  14. I've checked the forums for air bag light issues and never saw anything like this one. I ejected a cd and put in another with the key out of the ignition. when I started the car I had the air bag light come on. checked on a code reader and there were no fault codes, so nothing to clear. this surely puzzled me. sounds like a trip to my friendly mechanic for a computer hookup (he has durametric or similar software). anyone heard of this problem? any other way to clear the light? thanks to all...
  15. yes. good thought re sender replacement. hopefully a relative cheap fix, and sounds like that could really be the problem. the key was the straight line rpm. I'd go to 20-50 for the SC. good luck. let us know if the sender swap is the solution.
  16. ps: what oil are you using? maybe you need to use a different viscosity...?
  17. I think there is a tool that goes on the oil filler for testing oil pressure, but not sure. Does the problem happen when the engine is hot and you're going around a corner? If so, there is a traditional problems with older oil pumps that do not have a screen-like part on the pick up tube. on hot runs the intake on the older style pumps can be above the oil level in the sump. If that happens the car with either just stop or the oil pressure gauge will jump around. If your just idling, hot or cold, I'd bet the problem is in the pump itself. shouldn't be as they are really realiable as far as I know. I replaced mine "just because" we were into the engine box anyway. It's been sitting on a bookshelf in my office for years, and very very few people have any idea that it's a Porsche engine heart. Problem is that if your problem is the pump, you gotta take the engine apart completely to get to it, even taking the case apart, as far as I know. Loren would be the expert on this one I bet.... good luck.
  18. Only happened once, and that was after I replaced the battery and alternator. Only the word Porsche came up on the radio. I turned off the ignition, turned it back on the radio must have rebooted. If your problem is consistent I agree that it's likely a problem with the amp. good luck....
  19. and the back side....
  20. I'm going to be selling my 1979 911sc. send me a PM if you're interested, and I'll tell you about the car. It's not officially listed on any sales lists just yet. Cheers.... Here's a pic ...
  21. right, been there, done that. sometimes you'll need to repeat the process a few times. also, the alarm will beep once if you set it and something, like the glovebox, is open.
  22. there was some good info on this at 6speed. basically, with key on, lower window, hold button for 3 secs, then raise and hold for 3 secs. I had to do this several times before the re-programming took hold. and, just flic the switch for a nanosecond, any longer and the auto feature is disabled. hope this helps.....
  23. of course. my chagrin. sorry.... jl
  24. Your new engine should have all the latest parts. Yes, all the latest parts...but does that include any parts or refinements to address the cylinder wall failure? I am tracking that the only changes have been to address the RMS failure. Is this correct? Chris Chris, I'm a little discouraged by your experience, as I now use my 2003 as a daily driver. but, on the bright side, my '79 is going strong at 326K car miles, with about $11k in an engine rebuild at 160k miles. I know the sc's are probably the best Porsches ever, but I really hope to get some good mileage and reliability from the 2003. was your problem that required the new engine caused by the rms failure, or were there other related reasons? good luck to both of us...jl ps: I'm selling the '79 if I can ever get it smogged.
  25. Just realized there are two current threads running re battery/alternator issues. could this be an epidemic?
