AC Taken Out by U-bolt
Last week while driving on I-78 in eastern New Jersey a U-bolt flew off a vehicle in front of me and into my front left grill punching a hole in my AC coil. The bolt struck the piping just where it enters the coil. My question is does this coil also affect the car's cooling system? The temp seems to have jumped several degrees from 180 to around 185 - 190. My boxster is a 2002 S. Photos below show the u-bolt that was found below the front AC radiator, damage to AC radiator and where the puncture may have occurred, pin hole.
Edited by Tom C
The AC condenser sits in front of the cooling radiators. It covers maybe 95% of the front area of the radiator. Cooling air is expected to pass through the AC condenser and then through the cooling radiators - so if enough frontal area of the AC condenser is damaged it would have an effect on engine cooling.
If you haven't taken the front bumper off to clean the debris from the condensers and radiators this should likely be done too. Besides you will need to take the bumper off to replace the damaged AC condenser.
Whit a AC in good condition the cooling fans in the front of the car are working continuously ( 986 - 996 ). If the AC system is empty by a leak, the fans are no more activated and starts only if the engine temp. comes high commanded by the DME. Maybe that the US version is different.
The condenser has been replaced; I repaired the hole in the cowling with fiberglass, epoxy, and black paint; I repaired the broken grill with marine epoxy and the piece I found next in the pile of leaves when I took off the bumper. I'll have my garge charge and check the system.
I see they are now selling 134a these days. It appears anyone buy it, but you must be certified to use it?
Edited by Tom C
Tom,
Where I live a evac and refill of R134 is only about $120, I would expect to be under $200 in in NJ plus they can do the dye to check for leaks post repair if there is diminished cooling capacity.
FYI temps of 190F are fine...
Home kits are the best way to do this since you have had a full loss. You shouldn't still be able to buy 134a in quanity w/o a permit but the car stores have the little recharge cans.
