Procedure for entering radio code
Hi all.
The previous owner of my 928 swears I have the correct radio (CR-210) code: 1224. When I tried to enter it in place of the C O D E message, the 1 kept blinking, but no radio started. After a few tries, I began punching other buttons. "WAIT" appeared in the window, and nothing will get rid of it, not even disconnecting/reconnecting the battery, removing/replacing the radio face plate. Of course no buttons operate. I tried the press-and-hold-TP-for-30-seconds thing, the press-the-tone-button-then-8-&-0-together thing. Nothing happens at all. There are no numbers above the buttons, so I don't even know which ones are 8 and 0.
What should I do?
(What should I have done?)
Any help will be greatly appreciated.
From the CR-210 Owners Manual (which you can download here)...
"This radio renders itself inoperative in the case of theft. If the
radio or car battery is disconnected, the radio automatically
disables itself. Once the radio is reinstalled or the battery is
reconnected, the word "CODE", with a flashing letter "C", and the
digits 1-0 appear in the display. Prior to use, the correct code
must be entered via the multifunction keys.
Example: CODE 1530 (Preassigned to each radio and supplied
to the owner on the PORSCHE RADIO CODE CARD) is entered
by pressing the multifunction keys in sequence. (See diagram.)
After the first digit is entered, the word "CODE" disappears and
the number is displayed followed by three dashes. As digits are
entered, the next line in sequence flashes. When all four numbers
have been entered, the first digit flashes. At this time you can
overwrite the code as often as necessary. To correct any error,
you must enter the complete code. Once the correct code is
displayed, enter by pushing the signal seek switch.
If you have entered an incorrect code, the word "CODE"
reappears in the display. The system allows two more attempts
for a total of three. After three incorrect attempts, "WAIT" is
displayed. A ten-minute time interval must lapse before you can
attempt the coding process. You have three more attempts to
enter the proper code at this time. After nine attempts at code
entry and three waiting periods of ten minutes each, the radio will
"WAIT" for sixty minutes. After sixty minutes, you will have three
more attempts at code entry. Should you fail at this point, "WAIT"
will appear, and sixty minutes must pass before you can make
another attempt.
Attention: The radio must be on during the waiting period.
Note: The RADIO CODE CARD and window decals are supplied
with the vehicle. To avoid unauthorized use, do not leave the
RADIO CODE CARD in the car!"
