I read it was possible to register type II over-revs by bouncing off the rev limiter. Someone posted they had accumulated type II over-revs doing dyno pulls with no downshifts. I believe this claim because I was told by my tech I had 225-250 type II over revs on my 997S even though I had never mechanically over-revved the car. When I bought it, it was still wrapped in plastic and only a handful of people had driven it with me in the passenger seat each time. That car is long gone so I am only concerned that I will accumulate type II over-revs on my Turbo. What your thoughts?
The 6 ranges are:
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 3: 7700-7900 RPM
Range 4: 7900-8400 RPM
Range 5: 8400-9500 RPM
Range 6: 9500-11000 RPM
You really don't need to worry about anything other than ranges 4 to 6.
The 6 ranges are:
Informative post Loren. Does this scale ring true for the other 9x7 cars?
Cheers
Pop
The 6 ranges are:
Good info, Loren. Are these also the ranges for a 987S? Thanks.
The 6 ranges are:
Yes, the 9x7 series use the same DME (so far).
  • 2 years later...
loren,these ranges are car or rpm related?i mean does range 1 corresponds to same rpm range for e.g. a 997TT and 997Gt3?my car is 997TT tip and so there is no possibility to over rev it...i have range1,2 and 4 ignitions at range 3....How do you explain it?
Corrected Ranges for 997-1 series cars:
987 Boxster
Range 1 - 7200-7500
Range 2 - 7500-7700
Range 3 - 700-7900
Range 4 - 7900-8400
Range 5- 8400-9500
Range 6 - 9500 up
997 Carrera
Range 1 - 7200-7500
Range 2 - 7500-7700
Range 3 - 700-7900
Range 4 - 7900-8400
Range 5- 8400-9500
Range 6 - 9500 up
997 GT3
Range 1 - 9000-9200
Range 2 - 9200-9400
Range 3 - 9400-9600
Range 4 - 9600-10000
Range 5 - 10000-11000
Range 6 - 11000 up
997TT
Range 1 - 6800-7000
Range 2 - 7000-7200
Range 3 - 7200-7400
Range 4 - 7400-7900
Range 5 - 7900-9000
Range 6 - 9000 up
