my car is under cpo warranty but just want to check to see if this is a known issue.
Usually after drive a car a while and I want to do a "warm" start, the car would fire up but RPM will drop to 0 and stall, I tried it about 5 starts and just will not "catch". I can however give it some gas then everything is fine... it's an 01 w/ 8000 miles
Also i feel sometimes when holding a rpm/speed the car seems to "hesitate" a bit like i backed off the throttle but i don't think i did..
any ideas?
Fault codes are crucial, read out the memory and note the codes.
there are no stored fault codes....
What tool did you use?
Is it capable of viewing pending faults?
i used a OBD II reader...and came up with no codes...i don't think it's capable of viewing pending faults, it's from pepboys...
You need a real Porsche code reader....durametric, PST2 or PIWIS. I recommend the durametric, it will be well worth the investment.
I had a similar situation with my 99 996. It wasn't even giving a check engine light, but it wouldn't stay started. Turned out to be the mass airflow sensor. A local shop was able to diagnose with the Porsche code reader though.
any ideas?
Similar thing hapenned to mine when I fueled a fuel tank with 95 octane gas, instead of the spec'd 98 octane. It would stall when warm starting, despite it being a Tiptronic. Also some RPM fluctuation was noticeable, as you describe. After a proper 98 gas refuel, all went away.
Good luck, Luís
