Strut Spring Compressor
There is a lot of great information regarding replacement suspension components i.e. pss9/10, h&r..., but not a lot of information on the required tools. That said, what would you recommend for:
1. Strut spring compressor - is there a preferred type i.e. clamshell or double hook and screw type?
2. Ball joint seperator (I believe this is required to remove the front strut on a C4)
And one final question - once you've lowered the car are engine belly protection pans suggested?
Thx,
Mark
I use the finest $12 hook spring compressor that Harbor Freight offers to pull the coil spring tight. A pickle fork will work just fine to get the ball joint shaft loose.
thank you - that is the exact information I was looking for; didn't want to make an expensive mistake!
