RoW M030 Sport Suspension Install
by drpaulmarsh, Ryan Hanson & Hans Wiederrich   Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. Front Strut Removal and Installation: 1. Loosen lug nuts slightly and block rear wheels. 2. Remove the shroud on the trunk with a torx screwdriver. 3. Mark the location of the three (3) 13 mm bolts on the top of the trunk that holds the strut to the body with a ink pen. 4. Jack up the car and r
Edited by drpaulmarsh
  • 7 months later...
Very nice and detailed description that compeled me to try it on my '03 C2 Targa.
Before starting I need a bit of help clarifying a few things:
- Where and what kind thread locker or anti-seize is needed if any (I got the optimoly TA for the wheel bolts)?
- Porsche asks for the caliper bolts to be replaced. Do you find that necessary even for a 5k mile car?
- Could you identify the parts that you name in the torque lists in a diagram or picture?
- Anything special about the mounting of the stabilizer bars?
- On marking with ink the location of the top strut bolts, you mean put a circle around them to get the positioning identical?
- Is there a new alignment required once it's all done?
- How long does it take for the whole install and are there any special tools other than the spring compression tools?
Thanks a lot
Yannis
Thanks a lot
Yannis
One note. When I tried to get the front taken care of in a C4, the front halfshaft seemed to limit travel of the suspension enough that I could not get the strut out of the wheel well, even with a little bit of spring compression.
Does that half-shaft have to be removed (the whole wheel carrier I guess would have to be disconnected at that point) in order to get the front strut assembly out?
David
My C2 is done. Used a lift and a friend. Total work time from lift to drive off was about 2 hours. Including the time to put the skid plate in the engine. Helped a lot to have a lift and to have both a spring compressor and a pry bar for the rear shock/spring. Taking a little tension off then gently lifting with the pry bar made it a cinch to get the old units out. The pry bar also came in handy when installing the new rear units and trying to replace the bolt.
  • 4 weeks later...
I found that you can get an extra 1/2" clearance by straightening the tab on the welded strut aligment bracket.
Just loosen the bolt thru it and raise the strut then straiten the tab which then can be slid down into the slot in the clamp giving you 1/2" additional clearance for removal. I did it on the new ones also which makes it very easy to get back under the fender.
This method also allows a few millimeters of additional lowering by letting the stamped bolt hole rest on the bolt instead of the tab.
BTW this has got to be one of the best mods for a high mileage 996.
  • 5 months later...
Strut Install question: Does the caliper really have to come off or is this a precaution? I'm just about to start the install and wondering if I can leave the caliper alone. Maybe it has to come off to get enough travel in the wheel carrier? Thanks.
I think the two concerns are getting the wheel carrier down enough to get the strut out (and in) and not stressing the brake lines too much.
There are only two bolts on the caliper so most folks just take them off and hang them on a wire out the way (so they don't have to disconnect the brake line).
In case it helps the next guy, I'll answer my own question: The front calipers need to come off of the rotor to allow enough travel in the wheel carrier to get the strut out. The rear calipers do not need to be removed. Funny, this is exactly what the original poster's instrctions say to do. :notworthy:
Also, I've seen some posts where guys say they did the job without spring compressors. Working alone, I'm glad I bought a set - $50 from Sears.
Strut removal question:
I cant seem to remove the stabilizer mount from the strut spindle assembly and the strut seems to be frozen solid as well. Has anyone come accross this problem before? My cars done 126000mile so I expected a few rusty bits. Ive tried WD40, a bit rubber mallet, a screw driver to chip all the old bits away and quite a bit of brute force. Stuck solid. Any help would be very gratefully received. One thing I did think was that maybe I have to buy a new assembly and remove the old one at the base and build up again.
Many Thanks in advance.......
Andrew
It sounds like you are referring to the front strut ? Just make sure the pinch bolt is completely loose and use a pry bar underneath levering it up. You can work on the Sway bar link once you get the strut off and have more room to work.
Andrew
  • 2 months later...
