Hey Guys,
The other day I was making a left turn and my signal was on and as I did the turn I heard a plastic snap sound come from behind my steering wheel. Since then my signals work but the steering wheel does NOT shut off the signal after the turn. Loren, I was wonding if you could give me a column exploded view from Porsche? I don't think it is my cable reel for the ABS, most probably my combo switch, but I am curious, if I need to replace the whole switch or if it is a ring I broke or something
Model an year of your car please?
Wow am I an idiot... 2001 911 Turbo (996) US Model
:renntech:
Sorry, Porsche does not sell just the stalk parts only the whole assembly.
If you want just the turn signal part you might try a salvage yard. It is a little more work but a few folks have changed out just the turn signal switch.
Item 1 - 996.613.219.10.EWC is the whole assembly -- US MSRP $248.18. Sunset Imports (Porsche parts at Dealer Cost) can likely do better than that.
Plus 1 for Sunset Imports in Oregon....I buy all my 930 and 996TT parts from them and have found them to be one of the best in terms of price and service. They ship quickly and are very knowledgeable.
Chuck
Thanks for the Pic Loren, I took it apart actually and what I broke is the return plastic on the clock spring unit. The part that returns the signal back to go. Do any of you know how to take off the upper clip (grey) on the clock spring? I think I will need to replace it. And I already shop and the plugged porsche dealership :)
Thanks Guys...
Thanks Guys...
Once again, I am an idiot. :) I need the clock spring Loren. Part number and price by chance? Thanks a bunch.
You cannot remove the gray connector. You need to remove the 2 or 3 connectors depending on the transmission specs. 2 connectors for the 6 speed and 3 for the tip.
Thanks for the update guys. Ya I figured the plug thing a bit too late. I was quite surprised to find that the plastic part off the clock spring that returns the signal to the neutral position broke as I was driving.
Now my question is, I put it all back together as I wait for my part for the "plugged" :) dealer but my airbag light now remains on? Do I need a Porsche dealer t turn it off or did I mess something up?
Thanks again both of you...
I sure hope you had disconnected the battery. Whenever dealing with the steering wheel (aka airbag) it is wise to disconnect the battery. In any case you will need a durametric, PST2 or PIWIS to reset.
You will need the Durametric software, a PST2 or PIWIS tester to turn off an airbag light.
