Child Seat Detection / Air Bag Light & Durametric
Bought a child seat air bag disengage bar and specifically bought a durametric to clear the fault codes.
Note this is a fully rebuilt Boxster -- and in the process I installed the child seat bar
When I fired it up -- the Airbag light was on
Durametric will say I have Airbag fault codes -- including the child seat code.
I cleared all the codes -- but Airbag light did not go off --- checked codes again -- Child seat detected.
It allows me to reset that code and the all show cleared -- but then when I ask Durametric to check codes again -- it flags that Child Seat (only)
Thoughts --
Should I pull the child seat bar (PITA but can be done) -- and see where my baseline is?
Or am I missing something -- and the durametric can't really reset the child seat code?
thanks,
M
The child seat bar should be logged out by a PIWIS tester.
I was afraid of that ---
Looks like I will have to pull the bar (or at least disconnect it so that I can get through inspections .....
"Sorry officer -- I don't have any plates or registration because my air bag light won't go out" -- probably won't cut it :-)
Mike
Mike
Nothing like replying to your own posts --
But I simply unconnected the child seat bar -- and the airbag light went out -- so
looks like I'm good until I can find someone local to enable the child seat via computer.
m
