Does the kit include the stabilizer mounts?
Should I be looking for these numbers in the kit?
996.343.792.12 and 996.333.792.25
THanks in advance
Peter
geeez Loren - I think I am in trouble.  I purchased the ROW M030 "complete" suspension kit from a company in the UK(not Carnewal) and I have a feeling I am not "complete" or even correct :(
Front shocks - 996.343.041.18 are for a MY02. Although the parts list says they can be replaced with 996 343 041 21 (for MY03).
Front springs - 996.343.531.19 is correct. They should be marked Green and White.
Rear shocks - 996.333.051.22 are for a MY02 (again). Although the parts list says they can be replaced with 996 343 051 26 (for MY03).
Rear springs - 996.333.531.26 is correct. They should be marked Green and White.
Stabilizer - 996.343.701.04 and 996.333.701.19 (replaces 996 333 701 17) are correct.
996.343.792.12 and 996.333.792.25 are new stabilizer mounts since your new bars are likely larger in diameter.
Bump stops and compensation plates can be reused as they are the same. The kits vary so I've seen some with and some without.
So the only thing I see in question is the shocks. I do not know the difference between the MY02 and MY03 shocks. Perhaps it is just the manufacturer since the parts list says you can use the newer ones on an older car.
I'm trying to order from sunset as well
Loren, can you verify that the part number they gave me at sunset is in fact for my 03 6sp coupe.
000 044 500 27
The kit comes with all that you guys have mentioned right?  I have the cheapy oem std suspension now..
thanks in advance
I don't have a listing of what is in that Tequipment list. If it is the same (or newer numbers) as the one posted here you are likely okay.
THanks in advance
Peter
If the kit includes swaybars then the mounts come with the swaybars.
There goes my final excuse :)
Slightly off topic, but related. I've seen a couple DIY instructions for suspension R&R on the various sites. Is there an "official" manual you'd recommend for someone doing the job themselves? I'd like to make sure I get the torques right, etc. Also, I'd like something more detailed than "remove the rear carpeting".
You might want to PM "Chads996" (I know he is on rennlist all the time) b/c he just posted a thread about the install he did himself. He did everything except the alignment.
Edited by LVDell
  • 4 weeks later...
Loren,
I just received my RoW M030 from Sunset. All the part numbers check out with those listed above, except for the rear springs. I have a 2000 C4 Cab 6-Speed, the rear springs are p/n 996 333 531 12 marked Red/Green. From the posts above, it appears red/green is for a C2 cab, while brown/red is for a C4 cab.
Did I get the wrong rear springs? What are the differences between springs marked red/green vs. brown/red?
Also, the front shocks (996 343 043 13) were marked lilac and the rear shocks (996 333 051 13) were marked green. What is the significance of those markings?
Thanks.
996 333 531 12 is the correct rear spring for a RoW M030 MY00 C4 Cab with specific VIN numbers. Chances are that the folks at Sunset ordered by your VIN - so they should be correct.
Front shock marking:
White means Standard Running gear RoW/US
Green means Sport-type running gear RoW/US
Rear shock marking:
Brown means Standard Running gear RoW/US
Grey means Sport-type running gear US
Rear shock marking:
Rear shock marking:
  • 3 years later...
@loren
please advice if 996.343.531.19 is the corect part no for 996 c2 my 02 row m030 front sport springs.
i am confused since tequipment list that 996.343.531.11 is the corect one
also do you have any ideea if porsche offer the x74 front springs as individual parts?if so,they will fit in the strut standard assembly?
thank's in advance
Edited by ahamay
@loren
thank's in advance
996.343.531.19 is the correct spring for a MY02- RoW M030 Coupe.
996.343.531.11 is for MY01 and older.
Yes, you can buy the X74 parts separately - but the cost would likely be higher.
For X74 the springs, shocks, upper support, and bump stop all change.
@loren
thank's in advance
i went with row m030with i founded to be less harsh and more friendlly for bumpers and daily driving generally
row m030 installed today.
Gert and Maureen from Carnewal do theire job simplly perfect
however i have achieved around 25 mm instantlly and i guess is more to come after a few hundred miles.i persoanlly like it but is this normally?
quite of "low" for the white-green setup
standard was brown-blue
