window, hood and trunk
Hi
i have just got my 1997 boxster on the road and found that the windows and trunk release and hood release does not work . My battery was dead so i charged it and now all these problems.
Thanks for the help
Door:
The trunk and the hood releases on a '97 are mechanical, so those are unrelated to your dead battery or other electrical problems.
Do a search here and you will find instructions on how to open the hood and the trunk without using the releases so that you can inspect the operation of the release cables.
If both windows don't work, first check the fuses in the fuse panel located at on the left kick panel, just to the left of your calf when sitting in the driver's seat.
If the fuses are okay, then it's either the switch(es) (unlikely that both went bad at the same time), or the central alarm control unit under the seat. There is also a 15 amp fuse located at the back of the control unit.
Regards, Maurice.
MY98 had done that a couple times. I exit the car and used the the key to manually lock and unlock the door and that seemed to release the latch levers. I also had an ignition switch failure at about the same time. I'm not sure what caused it and it hasn't happened since.
  • 2 months later...
I know this topic is a little old as far as the post date. I have a 02 boxster and I had a issue with it recently. I parked the car for 2 days without using it. I came back to start the car and my remote to open the doors wouldn't work. My interior lights were gone on the door panels and the overhead light. The dashboard lights were lit up like they normally would be but, when I turned the key in the ignition the car wouldn't start at all. No sound. I had 2 solid bars where my sensor would normally blink. My trunk and rear hood wouldn't open either. If someone could give me some advice, I would greatly appreciate it.
Hi
Thanks for the help
Door:
Regards, Maurice.
:welcome:
Have you tried locking and unlocking your car with your key?
There is a procedure in your Owners Manual to reset the remote alarm timeout.
Hi
Thanks for the help
Door:
Regards, Maurice.
FWIT, when I have my car parked for more than 5 days the remote does not open the doors. After opening the door manually (using key and not remote) I found that the hood and trunk (what I thought were mechanical latches) wouldn't open either. Frustrated I just tried to start the car. After starting car and turning off, both latches were "reset" and I was able to open.
That is normal and in the Owners Manual (the 5 day shutdown).
