Hi Folk,
New to the forum and I think I found an 02 996 I am going to buy. Local car, sold by the dealer and just traded in. It has 56k miles and the dealer is willing to do the 60k service and CPO the car. They orginally said the CPO is not included in inital internet price ($30,500) and they are going to get me a revised price this afternoon.
So I was wondering if the CPO is worth it and what is a fair price for the CPO warranty? I really like the idea of the warranty.
CPO is very good. It cost the dealer about $1,500-2,000 depending on the model.
Can they CPO a 2002? That's getting pretty close to the cut-off date.
It was a late 02 car and there is about 4 weeks left for them to do it. Thanks for the infoon price.
Don't pay anymore than $1700 for the CPO. On that model car, that is what they pay. It's still a buyers markert and I think the new version CPO (8/2008 and newer) is worth it's weight in gold.
I bought a 03 6spd coupe from the second owner (he owned for 6 months, wife wanted a beach house so the car had to go) and I have the CPO until 2/2011.
I have used it 3 times already. When the RMS needed replacing I bough a clutch from Sunset and told the service manager to "throw it in" while the RMS was being done. So I paid no labor and got the clutch right near cost.
Edited by soverystout
My question may sound stupid; what is CPO?
:huh:
Porsche Certified Pre-Owned
You can download the brochure here
Thanks everyone for their reply.
So what do you think is a fair price for a 02 Coupe with 56k miles, lightly optioned? Cosmetics in pretty nice condition, no accidents, verifiable service history, 60k service done and CPO from the dealer (2 yrs)? I am thinkning $29-30, am I high?
:huh:
Here is a quick cut & paste:
ThePorsche Approved Limited Warranty offers full
peace of mind that in the unlikely event of your Porsche
developing a fault, the affected parts will be replaced or
repaired as required*** with no deductible. The warranty
coverage is limited to the following components:
• Engine: Engine block and all engine internal parts,
cylinder head(s) and valve assembly, oil cooler(s),
head gasket(s), manifolds, flywheel, chains/tensioner,
oil pan, oil pump, exhaust manifold, turbo charger,
clutch master and master and slave cylinders, and
all related engine seals and gaskets if related to
warranty repair.
•Transmission:Transmission case and differential
housing(s) and all their internal parts, clutch master
cylinder, clutch slave cylinder, torque converter, flex
plate, and all seals and gaskets.
•Drive Train: Torque tube, drive shaft assembly,
center bearing assembly, and drive axle with
constant velocity joints.
•Suspension & Steering: Steering wheel, rack and
pinion steering gear, power steering pump.
•Cooling System: Water pump, fan, thermostat,
radiator thermoswitch, and all related seals
and gaskets.
•Heating/Air Conditioning: Heater/air conditioning
regulation controls, a/c clutch, compressor,
condenser, evaporator, control unit for climate control.
•Fuel System: Fuel injectors, throttle valve housing,
air flow sensor, intake air distributor, intake manifold,
pressure regulator, temperature sensors, control
units, warm-up regulator, fuel distributor, fuel line,
air pump, and all related seals and gaskets.
•Electrical System: Fuel pump, oil temperature
sending unit, turbo charger water pump, alternator,
voltage regulator, starter, radiator fan switch,
ignition coil, ignition distributor, hall sensor, knock
sensor, distributor cap(s), rotor, ignition cables/
connectors, high beam switch, all electrical motors,
pumps, and all control units for the following factory
installed systems (if
equipped): Anti-Lock
Braking System,
supplemental restraint,
wiper/washer, intensive
headlight washer,
headlights, door lock, power
windows, rear wiper, rear
hatch release, spoiler,
cruise control, factory
alarm, Porsche Dynamic
all-wheel drive (Carrera 4),
limited slip differential (928),
tire pressure warning (928),
central information panel,
on-board computer, and
climate control.
•ABS Brake System
(if equipped): ABS wheel
sensors, control unit,
modulator, ABS
hydraulic pump.
•Supplemental Restraint
System (if equipped):
Air Bag control unit and
airbag sensor.
•Brake System: Master
cylinder, brake pressure
regulator, brake pressure
accumulator, brake booster.
Limitations.
The warranty does not cover:
•Batteries damaged
from storage
•Batteries damaged from
lack of use
•Tires damaged by
road hazard
•Tires damaged by
premature wear
•Parts that fail due to lack
of maintenance
• Normal wear and tear
• Cleaning and polishing
• Lubricants
•Air conditioner
refrigerant charge
•Glass Breakage
•Vehicles originating outside
of USA and Canada
•Unauthorized modifications
•Wheel balancing and tires
Validity.
For added convenience, your
Warranty coverage is included
in the purchase price. Since
the warranty applies to the
vehicle rather than the owner,
it remains intact and can be
transferred with the private
selling of your Porsche.
Porsche Roadside Assistance.
Your Porsche Approved vehicle
also comes with Porsche Roadside
Assistance, an exclusive support
service that offers added security
when travelling at home or abroad.
In addition to breakdown, accident,
transport and recovery, the
program includes a range of other
coverage services. Please see
your dealer for more information.
Peace of mind.
With the added security that
comes with comprehensive
warranty cover, you can now
look forwardto many thousands
of miles of even greater driving
pleasure from your Porsche.
*** Warranty Coverage: Porsche Cars North
America will repair or replace with a new part
distributed by Porsche Cars North America,
at its sole option, any factory-installed part
that is faulty in material or workmanship under
normal use. Warranty repairs will be made
free of charge for parts and labor at an
authorized Porsche dealer.
Edited by Loren
remove oversized font
What is the asking price?
:huh:
warranty repair.
and gaskets.
Braking System,
headlight washer,
climate control.
•ABS Brake System
modulator, ABS
hydraulic pump.
airbag sensor.
Limitations.
•Batteries damaged
from storage
lack of use
•Tires damaged by
road hazard
•Tires damaged by
premature wear
of maintenance
• Lubricants
•Air conditioner
refrigerant charge
•Glass Breakage
of USA and Canada
Validity.
Peace of mind.
Thanks guys.
Well, I bought an 02 C2 CPO in 2007 with under 40K on the clock for about 39K before taxes (it has 52K on it now, so pretty comparable), my point is that while I like the fact that they seem to be holding a little value, I think you can probably push a little on price. Make them an offer you can live with, and make sure they put the CPO paperwork through ASAP, follow up after purchase.
:huh:
$32K is too high for an 02 with that Mileage. Even with the CPO. Shoot for $29K.
:huh:
I just bought, through a private sale, a highly optioned 2003 C2 coupe in flawless condition with less than 36K miles on it and all past records for $32K. It did not, however, come with a CPO. The entire IMS (not just the seal) on this car was replaced under warranty in 2006. I am trying to decide if I should get a CPO, as it is still possible to do so through a regional PCNA dealer.
:huh:
I choose the 03 Targa with 30k miles. I took delivery last Monday. I bought it from my local indipendent shop with a 60 day warranty. They have done work on my Benz and previous 911 so i trust them. They did the 30k service on the car and said it's sound. So far it runs like a champ and i am a happy guy.
I would say if you can get a warranty great but don't make that the deciding factor on a car, if it feels like the right car, go for it and enjoy
