rear brake pads
  • 7 months later...
  • 2 months later...
  • 7 months later...
Sorry, I just can't take it anymore...I keep reading about 17" brake rotors on Cayenne forums, and feel the need to point out that there are in fact 25.4 mm in every 1.0 inch. Therefore:
380mm = 14.960"
350mm = 13.780"
300mm = 11.811"
As much as I'd love to have 17" brake rotors on my Cayenne, it just ain't so...
BTW, I believe the silver and red calipers between the S and Turbo are the same, just different paint color. Black calipers on the Cayenne V6 are smaller.
I also believe the 380mm brakes are only found on the Turbo S models, and on Turbos with the (very expensive) Powerkit option, which basically turn a regular Turbo into a Turbo S by changing intake mainfold, ECU, brakes, and etc.
Loren, I bet you're correct on that reasoning. Wheel fitment over big brakes it critical, and those numbers indicating minimum wheel size would make it easier to discern.
And still, 380mm is a huge brake rotor...the same diameter of the wheels on my VW Eurovan!
